Recommended Service Schedule
I bought my Jaguar from a used car dealer and looked through the manuals in the glove box case but didn't see the "Passport To Service" book. Is there any other place I might find this info?
I Googled "Passport Service" and found this info for
2002 and newer X-Type, 2000 and newer S-Type, 2003 and newer XK8 and XJ8
Annually or every 7,500 miles
Every 15,000 miles this work is added:
Every 30,000 miles this work is added:
Every 3 years this work is added, regardless of mileage traveled
Every 60,000 miles
Every 90,000 miles
- Change engine oil and filter with Mobil 1 0-40 or extended performance 5-30
- Check and top all other fluids
- Visually inspect undercarriage for problems
- Inspect tires and rotate every second small service
- Check wiper blades, replace if streaky
- Check windshield washers
- Check lights
- Check belts and hoses
- Check operation of air conditioner and heater
- Road test car and note any problems
- Replace wiper blades and clean washer nozzles
- Use Autologic to check for stored faults in the various computer systems
- Check handbrake operation
- Lubricate door locks
- Inspect exhaust system and service as needed
- Replace air filter
- Replace cabin filter
- Inspect battery and replace if 4 years old or if it fails load test
- Check serpentine belt condition - replace if cracked. Check tensioners and rollers.
- Inspect brake discs/rotors
- Inspect brake fluid level, brake hoses, and brake pads
- Inspect cooling system
- Inspect door hinges & locks
- Inspect engine
- Inspect engine mounts
- Inspect fuel system
- Inspect handbrake
- Inspect headlights, check aiming
- Inspect lights & controls
- Inspect seat belts
- Inspect steering system
- Check wheel alignment (front)
- Inspect wheel lug nuts
- Lubricate accelerator linkage
- Lubricate brake pedal
- Lubricate weatherstripping
- Torque propeller shaft bolts
- Change brake fluid, preferably in spring
- Change engine coolant, preferably in fall
Every 60,000 miles
- Change transmission fluid
Every 90,000 miles
- Replace spark plugs
- Change final drive lubricant
The following 2 users liked this post by cyberlinks:
ampiko (03-11-2023),
Rousta Bout (09-29-2020)
The real schedule is available as part of JTIS, which is a free download here.
In answer to your original question
In answer to your question and as stated previously they are on the stickies.
see:> S type/S type R Sup V8
How to guides.
Intro.
Manuals & Catologues.
the bottom file. I have attached all three to make it easier.
https://www.jaguarforums.com/forum/s...-diesel-67634/
I thought your post on service inspection items was most useful and more detailed in some area.
How to guides.
Intro.
The following 3 users liked this post by bydand:
There is NO requirement to use Mobil 1 or any other synthetic oil. 0W-40 is only one of four viscosities mentioned by Jaguar and not the preferred 5W-30.
The list missed the fuel filter completely. Ooops.
The spark plug change interval is way too long for the V6 and too short for the V8.
The coolant change interval is 5 years or 150K miles, not every three irrespective of mileage.
There's many more..................
Jumpin' Jag Flash (06-12-2014)
For giggles, I googled the maintenance schedule listed above and found
Jaguar maintenance schedules for Series II and III, XJ6, XJ12, Double Six, XJS models.
Who are JE Robison Service Company, Inc.? Never heard of them.
How to guides.
Intro.
How to guides.
Intro.
Oops indeed ... anyone who touts that the service regime for all V12s (using their ref this would include carb, efi early and later, HE etc) would be the same as for the range of XJ6s ... has maybe never owned them ... and certainly never maintained them.
The original manufacturer's carefully formed recommendations, despite rare lapses which quickly becpme known and revised, are generated from huge expenditures on R&D, engineering and service. Not directed to any posters here or generally on these forums, nonetheless I do find it somewhat amusing ... and so often predictably tragic ... when others seek to re-invent.
Cheers,
Ken
But please understand that, at least recently (i.e., the last 20 or so years), manufactures maintenance schedules are intended to minimize warranty claims. After the new car warranty is done most manufactures leave the owners on their own.
Hence such silliness as "sealed for life" transmissions, etc.
Jaguar - it's not an automobile, it's a Motorcar
An OEM has nothing to gain and much to lose by cutting back on maintenance, especially since the owner is going to pay for at their own cost. If cars were to fall apart the day after the warranty expires due to neglect the OEM would soon be out of business from lack of new car sales.
Jaguar's reputation today is till suffering from the evils of British Leyland even though the demerger was in the mid 1980s. Many will not touch an American made car due to the quality problems of the 70s and 80s.
People have long memories and OEMs know this all too well.
Had ZF told Jaguar to specify a fluid change at 100K miles, I'd bet not one potential buyer would have batted an eye.
