refilling coolant after leak
Hi Guy's....I just repaired a broken coolant system in my 2003 Jaguar S-type 3.0 litre. It appears to me that the coolant that was lost is not being replaced by adding coolant to the plastic resevoir. When the engine temperature began to climb above it's normal mark I shut it off and decided it would be smart to get some help. Is there a procedure for adding coolant and also getting any air pockets out of the system??? Sure could use some good advice......Thanks...........Dan
Top of page beside New Posts is Search...open and type in something like "bleed procedure or bleeding coolant system"
eventually you will get something, be persistant.
Bleed Value or Proceedure for 2000 S 3.0
This is one thread I found with my first search.
Good luck
aholbro1
08-05-2021 05:02 AM
