Relay for ECU on 03 STR?
I recently replaced the left side low beam light just to find out that it was a relay, I switch around the front fog lamps or horn relay with the HID lamp relay. After I switch it out the low beam worked. I then put the lamp and everything back together tried them again, and they didn't, I went back in and realized that I just accidently unplugged the igniter wire, no biggy. I put the wire back in, and made sure it worked again, and everything went nuts, my windshield wipers were going and all lights were flickering on and off. I now cant even get power to the car, when I turn the key to position 1, only my airbag light comes on, position 2, nothing. I read another forum about the ECU, but I couldn't find a relay, I put a scanner on the plug to read the dummy light codes and it picks them up. But I still cant even start my d**n car.
P.S. Horn honks when I open the door.
Update: since I messed with the relays I had my mind set that, that was the problem. I didn't think about the battery, I had no idea a low battery would cause that much of a problem. *Facepalm*
Received 13,198 Likes
Hi EzSTR,
Welcome to the Jaguar Forums! It's great to have you with us.
Thank you for posting your account. Since your post is sure to help others in the future, can you clarify that you resolved the issue by charging the battery?
Also, please visit the New Member Area - Intro a MUST and post a required introduction so we can give you a proper welcome.
Cheers,
Don
Cheers,
Don
Saemetric
12-05-2014 05:56 PM
