replaced fuel pump but its still not starting
Received 6,338 Likes
I replace the fuel pump, relays, and fuses. Then I changed the fuel filter and Techron to the gas tank and it worked. Does spring clip on the bottom hose just pull out? I never mess with one before. This has been an experience - if other out there no of anything else I can expect go bad on my 2004 S-Type 6 please let me know. I only have 73,000 miles on it
I'd suggest cutting open the old filter for an inspection. If the fuel in tank was bad enough to clog the old filter, it may also clog the new filter, not to mention wrecking your new pump, too.
primary cause = fuel pump. the first time I put it on I had to spice the wires because the connecter was a little different so I used the one that cam with the ford fuel pump. It was getting power so I went got some piercing run & tap wire connectors and reinstalled and came up roses. kr98664 what other problems should I expect with a 2004 Jaq S-Type V6 with 73,000 miles?
I've used them for many applications with good results, but they aren't my first choice for a critical application like a fuel pump.
If just joining wires end to end, I highly recommend butt connectors from Ancor:
Products Ancor
You can get them online from many sources, including Amazon. If you have a West Marine near you, they carry them, too. Very high quality stuff.
#28
Consider the gauntlet thrown down.
aholbro1 (09-23-2017)
