Replaced rear tie rods
So my new to me 03 w/52k miles is in excellent mechanical condition. However as I was inspecting the suspension before getting an alignment and new tires I noticed the rear tie rod knuckle (near the brake disk) were completely degraded and crumbling.
As a OEM design engineer I immediately saw the reason. Ford/Jag for some reason put them too close to the brakes. The large and sudden thermocycles of brake operation degrade non-metal parts quickly.
Having been a engineer working with Ford over the yrs I must say I'm very surprised at this situation.
In situations where we have big thermcycles and therfore a concern, we will simulate heat with CAD/CAE
, make physical parts and test.. Then evaluate if the parts will live up to maker mile / time standards. If ok we then write the SPEC for the material grade, get quotes, and then go from there..
In this case on the S-Type the only reason I can see they put the knuckle so close to the brake disk is because they wanted suspension geometry to be the primary concern. Not longevity. I am surprised at this because in my yrs of experience I've never seen a compromise like this for a production car.
Here is the part I bought: https://www.1aauto.com/products/i/1ASFK02056?trk_msg=153CDMFVDU6KD334ALPJMS9RVG&trk_ contact=K8J867OOHIU6P9BF8OH2O0561C&trk_module=tra& trk_sid=4FVS4FDODE409P4ENMECLL2J1G&utm_source=Tran sactional&utm_medium=Email&utm_term=https%3a%2f%2f www.1aauto.com%2fproducts%2fi%2f1ASFK02056&utm_cam paign=OrderConfirmation&utm_content=1A+Order+Confi rmation
Their quality seems to be 90% as good as the original part. The welds look sloppy but adequate. The strength seems to be on par. And the length of the threaded area is moved a little closer to the outer knuckle. Plenty of tool access during alignment so it's not a concern.
The car underneath is as clean as a whistle and all other bushings look excellent for an 03. But look at the condition of these rear (outer) tie rod joints!
Yep, everyone here will have to replace rear tie rods sooner or later. I replaced ours years ago and they are still holding up.
https://www.jaguarforums.com/forum/s...80/#post356251
All other parts on mine still look very good. It'll be interesting to see how long they last.
Received 2,632 Likes
As Rick (joycesjag) pointed out above, mine were initially replaced under warranty in April 2009 when the car had less than 25,000 miles on the odometer. It was a 2005 S-Type 3.0 built in May 2005. Rick clued me in to the issue as soon as he discovered how badly his wife's 2005 S-Type 3.0's boots had disintegrated. I immediately checked mine and found them to be cracked and flattened as well. I still had two months of the factory warranty remaining on the car at that time so I called my local dealership and made them pony up for new rear links on both sides of the car....
Just curious, did you notice any handling issues while driving with the failed tie rod ends?
Mine don't look nearly as bad as yours, but I will plan to replace them very soon. No real handling issues with mine, but the suspension doesn't feel as precise as before. I've just chalked that up to cumulative wear with 300k miles.
Karl, when I replaced Joyce's Jags, the boots were cracked as seen in the links provided here but the actual "joints" were still tight. I guess if I would have researched replacement boot covers I could have gotten away alot cheaper.
The replacements are still in good shape, the boots have no checking or cracking. Back in the day, I used Motorcars Ltd. for my replacement parts, when they were a forum sponsor. Now I choose SNG Barratt as they have taken up the cause of forum sponsor.
kr98664 (10-11-2018)
hi
Ive found nowadays if you bu these off places like ebay or your local parts place
the quality is shocking, the rubber boots are so poor quality they perish within 12 months, then not long after the joint fails, due to water and dirt getting inside
if you buy genuine one there some times double or tripple the price but they last, 10 times as long
so I wont buy non genuines ones any more, genuine ones are better value long term
so if its a keeper, genuine ones
cheers
Joe
cheers
Joe
Received 2,190 Likes
The dust shield/backing plate on the smaller rotored cars is the heat/backing plate shield. On larger rotors like the r equiped models theres and metal heat shield that covers the joing and the bolt passes through it top and bottom. Either way theyre rubber boots and just like tires they degrade with time. I have also said that for money out of your wallet i replace when theres play not cracked boots. If you replace for cracked boots and no play youll be replacing
2 to 1
2 to 1
just relating my opinion from working on them for 21 years with no miles to 300k miles. I have customers that have not even had boots for years and many miles that still dont have play in those rear tie rods. But if you have an ext warranty contract ill put them in all day. Or if it just bugs you and want to spend the money
