Replacement Lug Nuts
#63
#68
http://shop.advanceautoparts.com/web..._276693277___#
at $3.99 each.
#71
The thread is 12mm x 1.5
However the OEM Jag wheels use a flat washered seat, MOST aftermarket lug nuts have a conical seat, including the McGuard ones I used with my aftermarket wheels.
Riski, Id be REAL curious to see if you just used conical seat lugs on a washer seat wheel, as it will NOT properly retain the wheel. Be careful with that, because they will eventually back off.
George
George
#72
#75
Yes, c'mon and help out here Riski... Honestly, a proper lug replacement for $25 is the cheapest any of us have ever seen...Heck, even if it cost $40 that is still at least $60 cheaper than anything else we've seen...For me that will keep Olivia in diapers and formula for the week...so, yea $60 matters....
#76
Just ordered 40 Dorman #6111171 lug nuts for my 2003 Lincoln LS and my 2005 STR. Got a good price at Rockauto of $108.72 shipping included. Bad to hear about the one guy who had flaking chrome but I need them and have had very good experience with a bunch of Dorman products in the past. They have a huge catalog of parts.
#78
All 20 lugs replaced with MB579290
I have a 04 XJ VDP. With every rotate and balance for the past year, at least one lug nut wouldn't make it. So, finally got rid of them all for the Dormans. I ordered from Rock auto at $2.35 each in set of 10. Having spent $10 for each of the 3 lugs that were broken, this was a steal. With shipping I spent $56. I removed the old lugs and replaced with these and the wheels look stock. And not worrying about breaking the lugs was worth paying for a new lug wrench for the 21mm Dorman lugs. If you have an XJ, S-type, LS or anything else with the OEM Jag lugs, put the Dormans on and have the peace of mind that you or your mechanic can change your wheels when needed without issue.
Norri (06-27-2013)
#79
We used these on Peter's X type......fitted perfectly, fairly cost effective solution and no issues.
20 X M12 X 1.5 TAPERED ALLOY WHEEL NUTS FIT JEEP COMPASS PATRIOT WRANGLER | eBay
The locking wheel nuts have been binned!
#80
Any opinions on these?
20 Lug Nuts Factory Mag Style Toyota Lexus Scion 12x1 5 Lug Nut with Washer | eBay
