Replacing both rear subwoofers
2003 S type R, is there a decent priced aftermarket sub that fits in exactly where the original Alpines go with no cutting, wiring etc. I just want to take the old ones out and drop the new ones in with no hassle as I'm not great at DIY.
I can get the originals refoamed for about $80 each with shipping but was hoping I could buy a pair for cheaper.
Thanks in advance.
Thanks in advance.
Would honestly suggest you purchase either of the following:
Smaller footprint good sound
Infinity BassLink Powered subwoofer: 200 watts and a 10" sub at Crutchfield.com
Bigger FootPrint, Better sound
Either of these is going to be soo much superior to the bass you have now. It'll sound like a whole new system! Hookup is easy....
Thanks for the replies but I'm not looking for anything bigger or to do any more wiring or adding converters or cutting out part of the shelf or any carpentry work or having a sub sat in the trunk etc, I simply want to put 2 replacement sub/speakers in that are better quality and less expensive than refoaming ($160 for the pr) the originals but will fit and drop cleanly, easily into the existing holes the 2 Alpines are in now using the same screws etc and simply plug and play.
Is this possible, does anybody know?
flblue,
If you have to remove the woofers to have them reworked anyway, it may be in your best interest to take one out, measure it (diameter and bolt pattern), and then shop around either on line or at your nearest audio shop. If you want to keep it simple, this may the way to go. Best of luck to you.
Mike
Mike
Most car audio installations are somewhat involved. Installing a new head unit or even an amp and sub woofer is not that hard though. I've done a few write-ups:
Aftermarket Radio Running Wires
and
Installing Steering Wheel Control Module Aftermarket Stereo
and
Fraser Mitchell
10-01-2015 04:06 AM
Doug Dooren
08-30-2015 08:51 AM
