Replacing front engine cover gaskets 2003 S type 4.2L Base
I’m currently in the process of replacing the oil gaskets on the valve covers and front engine cover. I’ve removed the valve covers, pulleys, electric fan, crankshaft pulley, all bolts on the front cover and noticed that there are three bolts from the power steering mounting bracket that go into the front cover. I’ve removed two of those bolts and noticed there is third bolt behind the power steering pump that needs to be removed. What is the procedure for removing the power steering pump to get to that bolt? I’ve already removed the 5 bolts holding the power steering mounting bracket to the engine. Should I be aware of any other bolts or parts that need to be removed to get the front cover off? Any help or service diagrams would be appreciated!
