Replacing front sway bar bushings
Dimension247 (11-28-2010)
Received 2,193 Likes
the best thing you can use is a wobbler externsion that away the socket to wobble like 20deg. I like to use a air ratchewt cause there is not alot of room and it will buzz the bolts out. also a 13mm gear wrench with aflex head works best to the bolts closets to the engine. the wobbler on the ones you cant see. spray with lube on the bottom of the bolts to ease them coming out. take all bolts out. reace the bushings and spray the bolts thread with lube before you put them back in starting them a few thread by hand. start all 4 before you tighten any, then tighten them up and youre done. this is a very hard job under a car in the drive, and soooooo much easier on a lift standing up
My apoligies for not responding sooner big guy.. I read this thread a week or so a go and did some home work for you but, got cought up dong the dad thing, bllaa, bllaa, blaa..
Anyway I don't know if I’m to late but here’s what I found out about changing the bushing..
I don't think – see it as an big issue..
You would need to remove this bolt here on the front cross member and then split the metal cover’s remove the old and replace with new.. x 2 of course.
![](http://i264.photobucket.com/albums/ii195/TDC57/Jaguar%20rebuild/IMG_8594.jpg)
If you were thinking about replacing all of bushing, then you might want to see these connections, again I do see a big deal. Remove the wheel work within the strut and wheel well.
![](http://i264.photobucket.com/albums/ii195/TDC57/Jaguar%20rebuild/IMG_8595.jpg)
Anyway.. Hope that helps.. If not.. Well I tried.. hahaaa.
![](http://i264.photobucket.com/albums/ii195/TDC57/Jaguar%20rebuild/IMG_8598.jpg)
Top left of that final photo looks to be the DCCV that goes bad so often.
I only see 3 hoses on it but I thought there would be 5 for your era car.
Thread "Dual Climate Control Valve (DCCV) Source" here https://www.jaguarforums.com/forum/s...ad.php?t=27185
but check the part # on "Confirmed Crossed Referenced Ford Parts that work with our Jaguars" here https://www.jaguarforums.com/forum/s...ighlight=YG378
philwarner
12-06-2021 07:13 AM
Doberman_Fan
22
12-24-2019 06:21 AM
Fraser Mitchell
10-01-2015 04:06 AM
Doug Dooren
08-30-2015 08:51 AM
