replacing ignition coils
It is a 2001 3.0. According to the diagram i found in the FAQ the order goes like this (however, it showed an 8 cylinder instead of a 6)
7 8
5 6
4 3
2 1
Would it be the same order for my 6 cylinder just by omitting the last 2 cylinders of the diagram or is it different ? I also realized that the way the cilinders are aligned it looks like it goes just like this just because they are aligned in a step way, ex: first cylinder is to the left lower that the second one which would be at the right of the first one but a litle bit higher that the first one, and so on.
Also, i just changed the windshielf wiper motor. i found no ground connected to it but i see a spot for the ground. Any diagrams on this ? any website that would show how parts go ?
7 8
5 6
4 3
2 1
Ok, i changed the wrong coils :X, oh well. I have to clean the intake manifold, injectors and throttle body, however i can't find a throttle body gasket online, is it reusable ? I want to clean everything as i just ordered the valve cover gasket set, so i'm just gonna take advantadge of the car being apart for a few days and do some good cleaning in there. Anything else i should clean while i'm at it ?
Received 6,322 Likes
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
KarimPA
09-03-2015 07:32 PM
