Replacing standard radio in 2003 S-Type
Old 11-09-2023, 04:03 PM
scrannel's Avatar
I mean... does it say "Alpine" on the front speakers? If so, you have a separate amp.
Old 11-09-2023, 04:34 PM
Searay26's Avatar
No, it is the standard radio.
Old 11-09-2023, 04:53 PM
Searay26's Avatar
Originally Posted by JagV8
Yes, that diagram shows the same as the one I was looking at, only an antenna amplifier.
Old 11-10-2023, 11:13 AM
Bill400's Avatar
Originally Posted by Searay26
Installed a different radio yesterday...same result! Radio looks to be playing, everything worked, but just no sound. I also checked the fuses to the radio in the passenger foot area, that I found on a wiring diagram, and they were OK too. I guess I need to pull a door panel and look at a speaker....maybe test with another speaker. I'm stumped.
If you have the wiring diagram, you can test from the radio connector. Any handy test signal.
use an old earphone and connect to your iPhone audio jack. Play your iTunes while testing.
Even a 9v battery may be used to test speakers: connect jumper wires to the appropriate terminals for the speaker that you want to test and brush the other end of the jumper wires across the battery terminals.
As Clubairth1 explained, if speakers failed, repair may be accomplished with a simple solder connection at the terminal strip. However, if the braided copper crumbles when you touch it, replacement speakers may be in order. Good luck, let us know how you resolve the problem.
Old 11-10-2023, 08:44 PM
Searay26's Avatar
Thanks, a friend of mine mentioned the 9 volt trick to me today. Wish I had known before the put the radio back in!
GreatMaStEr
03-30-2019 04:09 AM
hlotero
11-20-2018 05:53 AM
Tenagarlick
12-16-2013 02:17 PM
ccm5385
16
10-28-2011 06:40 AM
manderson10
12-29-2008 07:26 AM
Quick Reply: Replacing standard radio in 2003 S-Type
