Restricted Performance
2003, S-Type 3.0 5 speed manual transmission 90000 miles
The car developed an octane knock and set a knock sensor code P0328 [ sensor on the right side above the starter]. I changed both knock sensors and now I have no Octane knock; but P0328 is back along with restricted performance message. Car will not rev above 3000rpm while driving. What should my next step be? Thanks
Received 2,677 Likes
Best to start with knowing available voltage as many electrical faults or gremlins are caused by low available voltage.
Use a voltmeter to read voltage across the battery terminals after the ignition has been in the OFF position for at least thirty minutes. There should be a minimum of 12.6 volts available; if not, charge the battery for five hours at 2 to 5 amps and retest.
kr98664 (03-27-2024)
