restricted performance after heavy rain
A week ago my Jag was parked outside during a heavy summer storm. In the morning I fired it up- it started normally withut any problems whatsoever. A few minutes after that I got the restricted performance message and a yellow engine warning light. The car was working fine and after a few miles all went away. Since then no messages have reappeared. I guess some water might have entered in the areas around the coils. Should I be worried? It is the first time that I get this kind of a warning. The car is a 2006 v6.
The windshield scuttle or cowl is not longer sealing against the windshield. Multiple threads on various fixes. You are correct in thinking COPS got wet. I would put full attention on correcting asap.
I myself removed the scuttle, applied two beads of caulking across windshield, reattached cowl. Bobs your Uncle!
Definitely read the codes. On my 4.2 STR the knock sensor(s) will cause restricted performance if the car sits overnight in inclement weather. The RP goes away after the car is brought up to operating temperature. Pending codes can be read for this fault although not sure that they are stored once RP goes away.
