Restricted performance, auxiliary coolant pump?
Robinb (04-23-2013)
It's now 2 weeks since the intercooler coolant pump from Eurotoys was fitted to my '05 STR. After 3 tanks of gas, everything looks good, no more "Restricted Performance" messages, car is going really well.
So, to sum up this thread:
"Restricted Performance" message + error code P2601 indicated supercharger overheating due to a problem with the intercooler coolant pump, not the auxiliary coolant pump. Car still driveable, but supercharger no longer available. First thing to do is check the 15-amp fuse F36 in the engine compartment, adjacent to the w/washer fill-up.
Pump price: From Jaguar, around $600. From Eurotoys, $309 less whatever discount you can negotiate (I got 20%).
The Eurotoys pump is physically larger than the OEM, and has a higher flow rate of around 5-6 gallons/minute. Seems to fit XKR's and XJR's without too much trouble, but a new mounting bracket had to be fabricated for installation on the STR. Total (indie) labour just over 2 hours.
Welcome to the forum!
You need to visit our New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
ManyJags (11-19-2012)
#28
Received 6,304 Likes
This can also help bypass some of the new member restrictions and allow you to enjoy the site more fully.
Also this is the S Type section if you have questions on your XJR you should post in the model specific tech section. XJ ( X350 & X358 ) XJ6 / XJ8 / XJR - Jaguar Forums - Jaguar Enthusiasts Forum
Welcome to the forum.
#30
#31
#32
I have an 03 str with 135000km that is having issues somewhat similar to what I read here. Maybe someone can hopefully point me in the right direction. The car recently showed restricted performance and prior to this it was shifting rather hesitantly from 1st to 2nd I kept reading transmission related things but recently the dash lit up with the engine light and restricted performance, it drove without much power from the engine and i drove it back home and shut the car. When i started it 2 hours later the restricted performance went away and it seemed fine aside from the car shifting from 1st to 2nd with kind of a hiccup. any suggestion?
#33
#34
I'm not familiar enough with the STR's but I bet it's a very similar setup to all the Jaguar S/C V8's. I had a failed I/C aux. pump and got the RP code when ever I was climbing hills at freeway speeds---the supercharger was under additional load (more heat) at longer time intervals versus cruising around town. That's the only time I got RP without generating any OBD codes. You should hear the whine of the I/C pump running when the ignition is on but the engine not running. My I/C pump was located in the right (passenger side) front area of the engine. Another indication that the I/C coolant pump isn't working is when the top of your intercoolers are hot as a match head.
Replaced pump.Connectors all seem good.New fuse and relay. Fuse has dim light???? Any ideas.
#35
![Smile](https://www.jaguarforums.com/forum/images/icons/icon7.gif)
9 times out of 10 the hella pump is perfectly fine and there is no need for a bigger pump or a new pump as it is a very good solid pump,
if the fuse is good then the culprit is the pump connector on the other side where the cable gets T'ed behind the radiator which gets damaged and shuts the pump off intermittently,
an easy fix without removing the bumper etc..is to remove the center front grill (super easy) to have access to the connector on the other end (pump
side,easy access side),cut the power supply connector cable with the connector still attached to the pump,make a cable neg/positi using the connector,connect the black to any ground on the car and solder the positive on the 15amp fuse F36 (sc pump) with a cable extension,great majority of restricted performance due to pump malfunction are the power not being delivered to the pump and the SC overheating,the 12v needs to be taken from the fuse 36 as the pump should only run when the car is on .
01, 05, 2005, 30, aux, coolant, images, intercooler, jaguar, p2601, performance, pump, reset, restriction, sc, stype, supercharged, type
