restricted performance & engine light!
Old 05-18-2011, 07:25 PM
carlorner's Avatar
Default restricted performance & engine light!
i am pissed this seems to happen every time it rains, wtf.. i am going to have to take it to the dealer and hopefully not get screwed with a huge bill... what is a decent code reader that i can buy for cheap so i can see the codes too? i understand some dont read jaguar so please one that works on our cars.. what could be rain,moisture sensitive on these cars? mass air flow meter? last time this happened it said bank 1 to lean, and data flight recorder, and a few other like climate control module and anti theft?
Old 05-18-2011, 07:39 PM
Gus's Avatar
Gus
Gus is offline
Received 2,213 Likes on 1,702 Posts
Go to any AutoZone, PepBoys or Sears and get the codes read without them it would be hard to say what is going on. Then tell us what kind of car model and year car we are talking about because you do not have it in your signature. As for an OBD reader you will have many to choose from and this link will help. OBDII Code Scanners ** Member Approved ** - Jaguar Forums - Jaguar Enthusiasts Forum
Old 05-18-2011, 07:45 PM
carlorner's Avatar
2003 stype r, i thought i set it up on signature and posted pictures, ill check
Old 05-18-2011, 08:05 PM
qikcat's Avatar
I just found out the other day if your posting mobil you sig won't come up... Just FYI.
A lot of codes at once could always be the battery. If it's moisture related a lot of guys get TB codes and restricted proformamce from the sensors getting wet and corrosion.
Get the codes and I am sure they can't get you on the right track.
Old 05-18-2011, 08:09 PM
Gus's Avatar
Gus
Gus is offline
This post is from my Droid as a test.
Michael Star's Avatar
Sounds like water getting in the electrical connections at the throttle body.
Old 05-18-2011, 08:18 PM
Gus's Avatar
Gus
Gus is offline
That seems to be the problem lately, but getting the codes will help confirm.
Old 05-18-2011, 08:19 PM
Ya, I am just waiting for my car to do it
Old 05-18-2011, 08:28 PM
Gus's Avatar
Gus
Gus is offline
Every time I remove a plug / connector I clean the connectors with CRC contact cleaner, check the connectors for a snug fit and add CRC Di-Electric grease (in moderacy). It keeps it clean, dry and has eliminated a few of the poltergeist situations.
Old 05-18-2011, 08:31 PM
carlorner's Avatar
the last time i drove it was a week ago and all was fine, it is parked outside in driveway and has rained for past 3 days, but i checked under hood nothing looks wet... but i started it tonite just to see and there they were the lights from hell... last time it did it was in am after a long day of rain before... i am starting to stress this this car is sooooo nice i just hope it doesnt turn out to be a nightmare
Old 05-19-2011, 01:07 AM
JagV8's Avatar
Received 4,540 Likes on 3,949 Posts
It doesn't need to be wet when you look, either wet or damp before you looked will do
It can also be water leaking from the windshield (here: windscreen) washers.
Others have had this so Search can help but concentrate on V8 engines, especially the STR, because the TB and other items move (but, for example, all V8s have the same water-in-plug-wells problem if water gets in).
Another place: look in the trunk near & under spare tire for any signs at all of damp/water. (And do another Search.)
Don't go to the dealer as this is fairly easy DIY, certainly as yet.
Old 05-19-2011, 07:17 AM
carlorner's Avatar
Default ?????????????????????????????????
checked trunk, all dry.. battery is a no name but seems real new{ it does have a little vent tube on it that runs out my tail end; if this is any clue, this mornin i started it and the restricted performance light was gone, but engine light remains, everything looked clean and dry under hood, need codes read now
Old 05-19-2011, 07:39 AM
JOsworth's Avatar
As others have said.... Water is the enemy... Here is what happens: Water drains from the windshield cowl onto the back of the engine.. On the R the throttle body is mounted to the rear. It gets wet and water gets into the throttle position sensor connector..Then all h*ll breaks loose. Do a search on Limp Mode and you will see a great many threads about this. Some may be linked in the FAQ section at the top of the S Type page.
First thing I would do is what Gus talked about. Pull the connectors, clean with contact cleaner then apply the die-electric grease... I did that when I had my 05.. Used to take it through the self serve, hose it off car wash during the winter... also used to spray down the engine with Gunk engine cleaner about twice a year and hosed the engine off with the garden hose...Traded it with over 70k on the clock and never had a Limp Mode issue...
Old 05-19-2011, 11:49 AM
carlorner's Avatar
got code p1582 and p1699 flight recorder data avail? and can??link engine control,climate control module... any idea where i shoul start? or take to dealer?
Old 05-19-2011, 12:56 PM
JagV8's Avatar
flight... means car stalled in a certain way so for now ignore it (won't cause RP)
the other may be transient, clear it and see
Old 05-19-2011, 01:13 PM
Gus's Avatar
Gus
Gus is offline
Use this link to interpret the codes http://www.gusglikas.com/images/Auto...tos/P20003.PDF the codes refer to a stumble. This problem could by electrical or fuel but with the rain I would venture to say it is electrical. I would first check the TB connections because it seems to be a common problem in the past.
Old 05-19-2011, 01:19 PM
Mafioso's Avatar
I know exactly which connector is causing this, Give me about 20 min, and I will go snap a pic of it.
Old 05-19-2011, 02:52 PM
carlorner's Avatar
mafioso please do, i just went home to drop off at dealer and engine loght went off about 30sec after start up, wtf!! so i bit the bullit and dropped it off for a check up anyhow... i ll post when i pick it up? please post pict of that to just in case i wasted my $ at dealership like i probably know i did.. and im in on that next group run on intakes
Old 05-19-2011, 03:17 PM
Received 6,330 Likes on 5,516 Posts
I fixed that for you.
Good luck with the gremlins.
Old 05-19-2011, 04:32 PM
carlorner's Avatar
Default dealer says
p0332, p0301.p0303.p0307 he states water is running down the wiring harness and getting on the coils, $60 a coil to replace-$650 labor he said i could remove coils and put a thin bead of silicone on and that would fix that... and the knock sensor code( i put 87 octane in last week and it would chatter under hard acceleration)- i am gonna have em clear it and run a tank of 94 octane and see what happens as he states the knock sensor is inside the engine and is about $900 to replace- sooo ummm nooo... i am gonna keep this car covered when not in use also to see if this helps..
Quick Reply: restricted performance & engine light!
