restricted performance & engine light!
Old 05-19-2011, 05:36 PM
Gus's Avatar
Gus
Gus is offline
Received 2,213 Likes on 1,702 Posts
Find the problem then fix it, putting a cover on it is not the answer. As for the codes when did the additional codes come in? Water in the coils does not mean you need to replace them it means you need to stop the leak and just clean and dry them! I am not sure what you have going on but unless the coil test bad why replace it. As for the knock sensor, it does not like water! Clear the code and see what takes place, if you think the octane level is the issue up it to the next level and see what takes place.
Old 05-26-2011, 03:01 PM
JagJockey's Avatar
Gus, would you happen to have access to the code references for a 2000 XJ8 VDP? I had to at least ask, Thanks
Old 05-26-2011, 04:22 PM
bmw745ion19s's Avatar
Originally Posted by carlorner
p0332, p0301.p0303.p0307 he states water is running down the wiring harness and getting on the coils, $60 a coil to replace-$650 labor he said i could remove coils and put a thin bead of silicone on and that would fix that... and the knock sensor code( i put 87 octane in last week and it would chatter under hard acceleration)- i am gonna have em clear it and run a tank of 94 octane and see what happens as he states the knock sensor is inside the engine and is about $900 to replace- sooo ummm nooo... i am gonna keep this car covered when not in use also to see if this helps..
i hope putting 87 octane in your car was an accident, if not shame on you.
good luck with your problems though. Id suggest looking for a good independent service specialist in your area.
Old 05-26-2011, 08:10 PM
Gus's Avatar
Gus
Gus is offline
This should help http://www.gusglikas.com/images/Auto...J27%201999.pdf
Old 05-26-2011, 09:04 PM
carlorner's Avatar
Default Help
It's been a week since I drove car ,today started and restricted performance light, then engine light!! Ran it for 15 min shutoff and restricted petformance light went out but engine light stayed on,, I am so tired of this. Should i replace 1,3 ,7 coils like dealer suggested??? and Also bank 1 knock sensor( i still have 1/8 th tank of 87 octane that was put in on accident ??? I need help. Is anyone in the Allentown pa area that knows a good jag specific mechanic? Bennett jaguar / land rover is overv priced. $980 for 3 coils replaced, and $ 1200 for knock sensor!! Wtf!!!
Old 05-26-2011, 09:17 PM
phd12volt's Avatar
all nalley jaguar and see what the price is from them
Old 05-26-2011, 09:26 PM
Gus's Avatar
Gus
Gus is offline
What are the codes now? If it is 1, 3 & 7 coils then I would want to know why the car was running fine and then die again. Was it raining again? The knock sensor will indicate when a cylinder in misfiring. What is causing the misfire?
  #28
Old 05-27-2011, 09:15 AM
carlorner's Avatar
Po332 knock sensor circuit low bank 2 cleared code and put in 1/2 tank of 93 octane, let's see what happens next
Old 05-27-2011, 11:10 AM
achysklic's Avatar
Why only half a tank of 93 octane? I would fill her up dump a bottle of octane booster in and all is well.
  #30
Old 05-27-2011, 03:51 PM
carlorner's Avatar
ummmm 4.39 a gallon and didnt get paid til later. lol!! but it seems to run well and its 90 degrees out
Thempsc
09-07-2015 02:29 AM
big d
09-03-2015 07:37 PM
XFR_Gold
UK & Eire
09-02-2015 06:30 AM
lee,lee
08-31-2015 04:35 PM
Terrance Williams
08-26-2015 11:50 AM
Quick Reply: restricted performance & engine light!
