Restricted Performance - Warning
Old 01-18-2008, 02:55 PM
Cajun Mojo's Avatar
Default Restricted Performance - Warning
I had ask this question once before "in the S-Type Forum"but with no reply's.
So I will see if the second aroundtime is the charm "with this Forum".
This scenario happen to metoday:
While cruzing around 65mph I went to pass a another vehicle.
I floor it and when I get ahead of the car my Jaguar losses power. It is like
something gave way "no power to accelerate". And the Yellow Lite comes on
with a message in my display reading "Restricted Performance".
I am able to go about 65 mph "but zero power" , when I push the accelerator
down - nothing. I get off my exit and am going about 35 mph – still no power. It is like
it is running in reserve power.
When I get to my destination , I turn the car off. I then start the car back up
and take it done the road, it is fine now.
This is the second time this has happen in two weeks.
Any suggestion’s would be greatly appreciated.
2006 S-type 3.0
Old 01-18-2008, 04:41 PM
ken@britishparts.com's Avatar
Default RE: Restricted Performance - Warning
Stumped me. Are you out of warranty? I see the car is an '06.
Old 01-18-2008, 06:09 PM
Does the check engine light stay on after restart? Restricted performance would normally leave CEL illuminated.
2006 S-type, from the sound of it, sounds like possibly throttle pedal or throttle body.
Without codes hard to say. 06 should be in warranty unless miles are high. I just had an 06 XJ with 121000 miles in the shop.
Old 01-25-2008, 09:31 AM
super_jag's Avatar
mine says the same thing but the only codes that were pulled was lean bank 1 and leand bank 2 I think that is how its worded.
Old 01-25-2008, 02:40 PM
super_jag's Avatar
what do you think FJT is it the IMT seals like you said I haven't had time to take it to my jag guy cause it's snowing I don't want my baby to see snow, its garaged right now.... but it might have to.
Old 01-25-2008, 06:16 PM
Super, what year and engine size do you have?
Old 01-30-2008, 03:09 PM
super_jag's Avatar
I have the 6 cylinder, the codes coming up are p1000 (according to the dude who check it he said it was a dealer code) and P0420 Catalyst System Efficiency Below Threshold (Bank 1)
Old 01-30-2008, 06:21 PM
Super Jag, if you have a P0420 codes then you need a catalytic convertor. P0420 is for bank 1 catalyst below efficiency. If you care is within 8 years or 80,000 miles, you should be able to get it covered under warranty.
PM last six of VIN and I can look it up.
How many miles you have on there?
Also if you have lean codes for bank 1 and bank 2, if you have 2000-2002 S-Type then it is probably the lower breather hose or the upper breather.
Old 01-31-2008, 09:24 AM
super_jag's Avatar
Well another SOL incident it has 86,280 miles, so I guess I have to buy a new catalytic converter. When the guy read the code he said just to change the o2 sensor and it should be ok, should I do both? Oh and its a 2004
Old 01-31-2008, 10:31 AM
super_jag's Avatar
Well the dealer is coming to my office to pick up mybaby tommorrow, we will see what happens, I'll keep my fingers crossed so I don't have to tap into my vacation funds to pay for the repairs.
Old 01-31-2008, 06:03 PM
You should only need to replace the one thats bad. Once it is out of the car, they can look down in there and see it all crumbled apart.
The labour shouldn't be any more than an hour. The part may be pricey....precious metal in that piece.
Old 02-06-2008, 11:08 AM
super_jag's Avatar
Well I talk to them and they said that it gives them two o2 sensors on one bank and that it is a downstream code, something like that, they called to get the price and they said $150 a piece. So total for install is $355 is what he quoted me, including labor.....I just have to wait for them to come in, probably Monday. This jag mechanic is going to pick up my car Monday in the morning and bring it back in the afternoon after he is done with it.
Old 02-06-2008, 05:33 PM
I hope the O2 sensors fix it. I have never had luck replacing the O2 sensors once the P0420/P0430 codes rear their ugly heads.
Good luck.
Old 02-06-2008, 09:09 PM
jhe2003's Avatar
You said you had both banks lean codes right? When P0174and P0172 are flagged at the same time you will get a restricted performance light, being leanand some randon misfiresmight be theroot cause for your cat to fail, just a thought.
Old 02-11-2008, 10:08 AM
super_jag's Avatar
Well they replaced the the O2 sensors and everything was a ok on Saturday. Sunday afternoon the check engine light turns on and the Restricted Performance is on again. I drove this morning and it starts to buckle a 3k rpm, but after 1 minute of driving it turns of. I will call this guy to tell him the problem. Will see what happens.
Old 02-15-2008, 12:14 PM
super_jag's Avatar
Well he look at the lower brether hose and saidit was fine then he cleared the code and told me to call him if it came back on. Well two days passed and the light came back on and the Restricted Performance message came on. Well its going back Monday to get looked at. Guess no luck with the O2 sensors I wanted to tell him that I doubt that both O2 sensor would go out at the same time but I don't want him to think I'm telling him how to do his job. I didn't pay for the O2 sensors anyways the dealer who sold me car is paying for the labor and parts to get the car up to par. I don't know what can be wrong, I mean the car drives perfectly fine. Maybe its just the IMT seals the JFT was mentioning on another post.
Old 02-15-2008, 01:46 PM
What year is it?
Maybe coils if it is bucking at 3k.
P0430 code still bothers me. I feel cat maybe stopped up.
Old 02-15-2008, 03:23 PM
super_jag's Avatar
That is what I'm leaning towards a bad cat.... It bucks because of the restricted performance message makes the auto go into safe mode, limp mode which won't let it go past a certain rpm, then around 20 mphrestricted performance messageturns offbut the check engine light stays on, then it will go past 3k rpms.
Old 02-16-2008, 04:55 PM
LOL.....if it is the Cats you owe me a beer. Said that back on the 30th of January. Let us know.
Old 02-18-2008, 10:08 AM
super_jag's Avatar
You got it my friend but not just one, if i ever head your way we will grab a couple.
Quick Reply: Restricted Performance - Warning
