Restricted Performance - Warning
Old 02-18-2008, 06:32 PM
Default RE: Restricted Performance - Warning
[sm=icon_cheers.gif]
Old 02-21-2008, 01:03 PM
super_jag's Avatar
Clogged fuel filter and there was a muddy substance in gas tank. Jag guy said that the problem is recent but I am going to get the mud checked to see if it is from Florida (where vehicle came from) and if it is then it was an existing problem and the car dealer will probably take care of it. If the substance is not dirt then I'm pretty much screwed.
FJT, the reason we were off is because it pop two new codes when they had the vehicle.
Old 02-25-2008, 09:33 AM
super_jag's Avatar
Well the check engine light is back and the Restricted Performance, same frakin codes P0171 and P0174.
Old 02-25-2008, 10:17 AM
What is long and short term fuel trims when car is under a load? Possible mass air flow meter.
Old 02-25-2008, 11:53 AM
super_jag's Avatar
Dont have a minimal idea on how to check that.
Old 02-25-2008, 12:02 PM
need to hook up to scan tool and read them. If they go to 20% or so mass air meter bad. -20% I mean
Old 02-25-2008, 12:06 PM
super_jag's Avatar
Well then I will see and report back to you
  #28
Old 02-25-2008, 12:10 PM
good luck
Old 02-28-2008, 10:15 AM
super_jag's Avatar
Well haven't had a chance to go get it checked out but the check engine light turned off and the Restricted Performance as well, has been two days so far and no Check Engine Light.... what you think.
  #30
Old 02-28-2008, 12:32 PM
Still look at the fuel trims.
  #31
Old 03-14-2008, 01:40 PM
super_jag's Avatar
Well I talk to the dealer that sold me the car and told him what happened (he was out of town), he is going to call the mechanic to go ahead and check the car once again. I will tell them to read the fuel trim levels to me so I can report back to you.
  #32
Old 03-14-2008, 02:32 PM
Make sure you check them under load. From stand still under acceleration.
  #33
Old 04-29-2008, 03:17 PM
super_jag's Avatar
Well found out it was th right cat
10 XF Premium
10-01-2015 12:47 AM
leep123
09-30-2015 03:41 PM
Old_Doc
09-29-2015 03:43 PM
Bigvettefreak
09-28-2015 03:03 AM
reb1999
09-26-2015 08:41 AM
Quick Reply: Restricted Performance - Warning
