retarded timing advise ! what Now .
#102
oh yea ! thanks for asking Joycesjag..
so ended up replacing the upstreams air to fule sensors with OEM denso also I got an old OEM denso MAF sensor from amazon for just 25 bucks ,, soon after replacing the MAF sensor i could feel ant read the difference mostly staying around 5.0 ... at idle and then i did replaced the (upstreams) air to fuel sensors also I got the original downstream sensors there ..also I removed and cleaned the MAP sensor placed it back ..
also did another SMOKE TEST AND EXHAUST PRESSURE TEST ( new tool PRESSURE GAGE TOOL I got from amazon ) FOUND NO LEAKS on smoke test and exhaust test - gauge pressure stays a bit past "0" on ALL four sensors inlet/outlet at CATS.. ALTHOUGHT WHEN measuring temperature with "infrared gun " at inlets / outlets at CATS BANK 2 probably around 30 degrees THE WORST BANK 1 around 45 degrees difference ..
I m thinking CATS may be contaminated previously car had blown head gaskets .. with past owner .
outcome NOW : after a week - CAR still idles rough when COLD START after warm up so much better.. so car has PENDING codes ONLY still has codes on " multiple misfires and bank 2 running lean " NO CURRENT CODES AT ALL AFTER A WEEK OF driving it .
ANOTHER ISSUE .. noticed it a couple OF TIMES when filling up with gas at full tank - Car leaks gas - looks like is coming from top of tank , it leaked around a half gallon last time i filled up with fuel. wondering if that is related to he ALWAYS THERE LTFT ON BANK2 HIGH 16.5 at idle it goes down to bellow 5.0 at throttle..
#103
jaimster (07-27-2020)
#104
NP. Aarcuda ..
I m at work and NOT driving the car today .. when i get home later today i can let you know .. let me know what to look for or where to start ?
like i stated : LTFT BANK 2 ALWAYS HIGH .around 16.0 at idle than it goes way lower . CATS temp seem to be to close to each other , I believe OUTLET supposse to be warmer at least 100 degrees than
INLET for what i understand !!
fuel leak another issue too. appreciate your help ..
#105
Recall on Gas Tanl Seals
Hi Jaimster
There is a recall for gas tank seals on your model. I wonder whether this has got something to do with your rich fuel mixture as a leak may change the mix of fuel and air ratio.
https://auto-recalls.justia.com/jaguar/s-type/2005/06v418000/index.html
CONTACT JAGUAR AT 1-800-452-4827
#108
You were silent again for a bit...you ok..man, when you get finished with that car it will be showroom....great job on the ac....bet it would be 2 grand at a shop....getting the damn belt on is a bear too
#109
so i called Jaguar corporate and dealer on the RECALL it turns out according to their record - RECALL was taken care back in 2007 .. they wont do it AGAIN. .. SO much for that .. i would never buy a new car from them.
on another note: this morning got bunch of codes CURRENT ones , misfires cylinder 1,3,5, and rate above limit one NO LEAN CODE ON BANK 2 any more . even thought LTFT BANK 2 IS HIGH 18.0 AS OF THIS MORNING !!
its kind of frustrating COLD START idles kind of rough.. ONCE it warms up runs pretty dam good..
Glad to hear you got a/c going man.. heat and huminity is brutal here in TEXAS stay COOL..
#110
#111
#112
Just for cold poops and giggles. Have you ever thoroughly inspected the intake tube and resonator box for cracks or holes? Look at this thread post #32.
https://www.jaguarforums.com/forum/s...-198690/page2/
This will not have anything to do with the gas spillage but, might help with codes.
The following 2 users liked this post by joycesjag:
kr98664 (07-28-2020),
S-Type Owner (07-28-2020)
#114
Have you pulled all 8 plugs yet? I need to see clear photos of the electrodes and what cylinder each plug was from.
As for the head work, did they just repair the one head? or both? If they milled one head and or i you used a non stock head gasket, the cylinder pressures wont be equal bank to bank and I believe that throws the ECU into kaniption fits as it throws an imbalance into the system.
#115
they milled both heads .. last time i did a compression test BANK 1 was around 175, 180 ,180 BANK 2 around 200 , 205,195 i will have to verify those numbers something like that , I posted the results a while back.
I got the head gasket from Rockauto.com !! i can take it apart friday again and post photos of all 6 plugs corresponding to cylinders ?
another question still .. what should the fuel pressure be at idle and open wide throttle for a 2005 s type 3.0 ? I know this model has NO shradder valve to mechanicly check fuel pressure , fuel pressure sensor was also replaced recently NO change ..
#118
#119
#120
this could be part of your issue. High pressure forces more fuel in causing a rich condition. How are you measuring it? .
