Reverse lights stay on?
Old 01-22-2016 | 11:16 PM
Jason Souhrada's Avatar
Default Reverse lights stay on?
Is this normal? These reverse lights stay on for 10 minutes after I exit my car and lock it up. Not full brightness, just a dim glow.
Old 01-23-2016 | 02:41 AM
JagV8's Avatar
No. Someone's done something.
At a guess, fitted LEDs.
Old 01-23-2016 | 07:47 AM
Jon89's Avatar
^^ Agreed. The usual downside of fitting aftermarket LEDs is that they tend to stay on for long periods of time after the car is shut down....
Old 01-23-2016 | 08:31 AM
Warspite's Avatar
I witnessed the same thing. I installed 10 watt LEDs, believing that would present a sufficient load, but they remained on, although dim. Removing one and replacing with original bulb eliminated that. I picked up an "experimental" bulb carrier from a wreck and will try soldering a resistor in parallel across the reverse light contacts and see if that eliminates that problem. Many LED kits include that resistor.
I also replaced the entire interior lighting with LEDs, and they work perfectly, with no "constant on" condition.
Designeer (07-09-2017)
Old 01-23-2016 | 03:51 PM
Datsports's Avatar
Ha I'll bet you guys are right I've been there too ! Also bewere of the positive earth frame on the back of the tail light cluster as touching that on the boot/trunk frame is a quick way to fry your RECModule ! It has a fuse but with mine it blew both the fuse and recm.
ajzride
12-04-2016 05:16 PM
R_Rated
02-06-2016 08:48 PM
BlownBrit
01-23-2016 08:14 PM
vnewtonXK07
01-23-2016 03:08 PM
Quick Reply: Reverse lights stay on?
