Revised trans service recommendations and pricing???
I know why they run the filter built into the pan. Its so you get proper pick-up through the filter to send the fluid through the trans. I used to have an Audi that ran the ZF 5HP24A trans and the pan and filter was seperate and if you bought a filter and replaced it you could starve the trans as most filter companies would have different length pick-ups. I've seen one that had the pickup right against the pan when installed so it was unable to pick up any fluid. I will stick with the stock setup so the clearance is perfect as ZF intended it. I ended up having to cut down the pickup when I did a trans flush on my Audi and hopefully I didnt cut too much or not enough.
I am still wondering how the dealer gets a four hour job out of this. I was quoted here by our dealer the same time. I hate to beat a dead horse, but once the vehicle is raised level in the air (2 minutes for a lift) or (maybe just less than an hour using jacks and ramps etc...) Its an hour and a half job, to unscrew drain plug, remove 21 or so torx screws (albeit the northern vehicles may take longer) drop pan, remove electric connection, pull sleeve lock, install new sleeve, replace new pan and new torx bolts. remove fill plug, add fluid, start vehicle (have a cold cheap beer), pump in more fluid, tighten fill plug.
That sounds long winded but really its not that bad of a job and surely NOT 4 hours!
Anyhow, like you said for the DEAlership to take 4 hrs to do this is a joke unless you have no clue what you are doing and if you are waiting for the Tranny to cool down from 131F+
I will allow myself four hours of daylight simply because thus far I have not been able to gain access to a local hydraulic lift or Jiffy Lube-type pit myself. The three shops I've spoken with thus far are concerned about liability and will not rent me a lift or pit, not even after hours. So if I had to do this job today, it would be with jack stands and working on my back. Not my preference at all. I'll keep searching for a Fast Eddie's like Rick found, but no dice so far....
One advantage of doing it on jack stands in my driveway is that I can allow the factory fluid to drain for as long as I want. Certainly at least overnight, and maybe even longer....
cheers!
I prefer to do it myself. I know I'll be a lot more meticulous about the entire process than a paid independent tech would be. Plus, as sensitive as these ZF units are, I want to doublecheck every step before moving on to the next one. Call me ****, but these ZF units are far too expensive to rush through just to get it over with....
#28
They also charge redundantly. I.e. If the connector sleeve books at 1.5 hrs, AND the trans flush/fill pan replacement books at 2.5 - they will charge you for both, even if the connector sleeve becomes a 5 min job when combined with the other repair.
That's my guess for how they get to 4 hrs book time, but if you're really curious I'll call my brother and ask him what mitchell estimator books it at.
George
#30
Vance,
Thanks again for your very kind offer. But it's a 3-hour drive to Camp Lejeune, and our car would probably need half a day to cool back down before we could do the ATF job. And I'm in no hurry - the car only has 51,300 miles on it. Still plenty of life left in our factory ZF Fluid. The only reason I would change it now would be if the connector sleeve starts leaking. Last time I checked (probably a couple of weeks ago), our sleeve is still fine (now knocking profusely on wood)....
Glad to learn that you're moving to the Triangle area. I thought that you and your lovely wife were headed to Florida after your stint in the military was finished....
I don't know anything about the local rental market. But I'll start watching the listings in the News & Observer and if I see anything that might be in the ballpark, I'll send the details to you....
Rather than tying up this thread, send me a PM on your house requirements (preferred location, square footage, one-story vs. two-story, garage or not, etc.), and I'll have a better idea of what to keep my eyes open for....
You might also want to google "Raleigh area houses for rent" and see what turns up....
#31
Vance,
#33
#34
For what it's worth. A couple of guys have tried upgrading with a copy and it hasn't worked.
It would appear you can utilize a copy to run once you've upgraded.
I think that's what people who sell their originals on Ebay are doing. So buy an original.
BTW, I have a friend who just bought a used A8 and on that car he was able to update & operate from a copy of the original disk. So apparently Jaguar is better protected.
#35
jagent
09-07-2015 05:00 PM
Wes Steenrod
09-06-2015 06:52 PM
