Rot/Rust/HOLE on rear subrame 3.0 S type
I was giving the car a good clean up behind the off side (rt side if stood behind car) rear wheel got all the crud off and WHOO....hello hello..a hole 1" across on the bottom + rot etc on the tubular section of the rear subframe which holds the top wishbone..it did not look good..Is this normal is the car dead..can it be welded.awfully near to a lot of brake pipes etc.
Any help much appreciated
Brian
Brian
It is a straight forward job to swap it out, but will take some time. If you can do it without taking apart the brake lines, it will save a lot of time. While you are at it, you should inspect all the control arm bushings and replace as needed. You will have to plan on getting things aligned after you swap the parts. If the car is rusted out I would suspect that many of the other parts have been exposed to the same conditions that caused it to rust in the first place.
Pictures would be nice of the damaged areas....
TCJAG88 (03-22-2018)
stanjag
08-30-2015 10:35 AM
WTT[MidAtlantic]: Mina performance S-Type Intake for sale
mkrion
08-26-2015 11:43 AM
