rotor size str??
UH Yeah....
That is another adventure in STR ownership!! ;-)
The STRs with the Brembo's use the following
365mm Front
330mm Rear
Most of us have used Brake Performance rotors drilled and slotted rotors work really well and have a lifetime warranty!!
Premium Dimpled and Slotted Brake Rotors
365mm Front
330mm Rear
Candy's Kitty (04-04-2013)
Check out these guys too
http://www.adamsrotors.com/gallery/?album=1&gallery=1
For those looking for something different. I did get a price from them of $250 for just a pair of STR front rotors. Drilling/slotting/coloring is extra.
I am going to try them out here soon
I always get these for my STR More Information for CENTRIC 12020018
same identical info that is on the brake performance site, they are however regular discs non slotted etc. They also carry the Akebono pads that work well. discs are $77 per unit
Well that is new one to me!!
I have had my 2005 STR front rotors cut without any problems.
If this is your first time ordering parts for an STR you learned a very good lesson.
The STR is a rare car. Most part sellers have no clue that they even exist. ALWAYS check before ordering. I have found there is very little for just the STR.
I think all of us STR guys have been bitten by that problem at least once! I know I have.
If i recall the standard pads that come with their rotors are semi metallic might have changed since the last time i looked there though
Cutting lathe
IMHO, with the low cost of the dimpled slotted rotors and the added benefits in stopping, cooling power plus the lifetime warranty against warping / cracking they offer, I dont see any reason not to just upgrade.
I think the real value of the the dimpled slotted rotors tends to get lost and overshadowed by the cool factor.
Thanks guys, one last question...
I see that dimpled, slotted rotors are highly recommended, but I also see that plain rotors are also available for about $50 less, and the Jag's rotors are also plain.
I understand that dimples and slots help to remove heat, dust and water from the rotors, but it seems as though there is a reduction in contact surface area because of these dimples/slots, maybe 2, 3, 4 or even 5%.
My question: If I just use the Jag for day-to-day driving, i.e. don't take it to the track, heat buildup is not really a problem. If I use Akebono ceramic pads, dust is not a problem. Can't see water being a problem either. So, am I not better off using plain rotors and getting (slightly) better braking from the greater surface area?
Robin, the stock (plain) rotors provide more than enough whoa power for average daily driving. Dimpled/slotted/cross drilled are the standard for the track as a means of preventing over heating of the pads. Go for the plain rotors plus Achebono ceramic pads. They provide more whoa power and don't dust/stain the wheels.
The following 2 users liked this post by bfsgross:
Bad Cattitude (01-24-2013),
Robinb (01-24-2013)
