Rotors/Pads
I'd like to give a slight upgrade to my front brakes and was wondering if you guys lean toward a particular combo. I've had factory Brembos on my Cobra in the past, but the OEM replacement slugs they sell for daily drivers are not quite up to the degree of their price tag. I'm leaning toward EBC rotors and EBC red stuff pads (gotta go British, right?). I've used this combo on my TL and have been very happy (no hub rust). I've also used ATE's in the past with great results. Your thoughts?
Multiple tests have shown that blank rotors outperform drilled/slotted/dimpled from a cold stop (most likely on a street setup)...When racing while the rotors usually remain hot, some setups may benefit from drilled/slotted/dimpled...So if you're looking for more bite on a street setup and are spending the big bucks on drilled/slotted/dimpled understand you could be wasting your money...I needed new rotors and went with a drilled/slotted setup for the soul reason of bling (and the fact they weren't too much more than OEM)
Received 2,263 Likes
Multiple tests have shown that blank rotors outperform drilled/slotted/dimpled from a cold stop (most likely on a street setup)...When racing while the rotors usually remain hot, some setups may benefit from drilled/slotted/dimpled...So if you're looking for more bite on a street setup and are spending the big bucks on drilled/slotted/dimpled understand you could be waiting your money...I needed new rotors and went with a drilled/slotted setup for the soul reason of bling (and the fact they weren't too much more than OEM)
![Icon Werd](https://www.jaguarforums.com/forum/images/smilies/icon_werd.gif)
Slotted and drilled are pure bling- nothing to do with improved stopping power on the street. What works on some cars on the race track doesn't inherently apply to street cars in traffic.
I put Raybestos brand rotors and ceramic pads on my non-R and couldn't be happier.
pab
07-28-2015 08:28 AM
FS[SouthWest]: 2003 Jaguar S-Type R
rasputin
07-21-2015 11:02 PM
