running a few codes
To add - P1383 and P1388 codes are related to the VVT system - most likely can be flagged due to oil viscosity issues - when was the last time you changed your oil? I would consider getting engine flush, idle for 15 - 20 minutes, drain and change oil to low viscosity (0W20, 5W20 or 5W30) and oil filter.
I typically run 1/2 to 1 qt of Mercon V trans fluid in the crankcase about 500 miles before my oil is due to be changed as trans fluid is highly detergent.
The following 2 users liked this post by abonano:
mikestype (01-09-2014),
vega1robert (01-24-2013)
Yep the P0174 is an air leak.
This link may help you out: https://www.jaguarforums.com/forum/s...ics-faq-52720/
Be sure to look at the link in the first paragraph in referance to jagreapir.com
As for the P1383, P1388 abonano has you covered!
Thanks for the help. I found the vacuum hose that wasn't connected put that back on. As for the other two codes right now I'm running 5w-30 semi-synthetic. if that was the problem would it make my car run different and sound funny. i last changed the oil about two months ago but that was before i changed the spark plugs.
Try 5W20 oil instead of 5W30 - I have a 4.0 engine & I had a persistent P1388 code - I am running Castrol 0W20 full synthetic right now through the winter... Now, they could be legit codes flagged by the PCM but they typically sound funny when the passages are partially clogged (from what I remember) If your passages are partially blocked the new oil should do you good. Also, use an engine flush additive before draining the oil - Good Luck!
So I did the engine flush and oil change/filter went with the 5w/20. I deleted the codes they have not shown back up, but I have the sound still coming from the drivers side. It's loud when I start the car and when I accelerate, but the codes have not come back. Just a loud car now.
