running rough but only at idle...attn techs
I have an 01 s-type v6 with random rough running condition. At any speed it runs flawlessly but as soon as you come to a stop it starts to idle slightly rough. It is not severe enough to die and will not set any codes. I have replaced all the coils and plugs as the valve cover gaskets were leaking and fouling out the coils. Fuel pressure is steady and well within specifications, ran 2 cans of bg fuel system cleaner through it and still have the same problem. No vacuum leaks, oil separator gaskets are good and sealed, intake gaskets good. Will not show change when introduced to parts cleaner or propane and sensors all show proper readings using datalogger.
any suggestions?
Thanks, Nick
any suggestions?
Thanks, Nick
