Rusty sills - how to! How bad can it be?!!! Lamb to the slaughter
Ok, here we go. Got a cheap 2000 S type 3 litre V6.
Plan is to restore and sell on in really good condition. Possible the only S type with rust free sills!
Did have a jag service history till about 2010, then......who knows.
Ended up with a gentleman who left it standing for 2 years because he wasn't allowed to drive anymore, and,.....................oh, this is boring, so lets get on with the rusty sills.
Sill cover off on the drivers side (remove the black clips from underneath, remove the mudflap by drilling out the rivet from underneath, and pulling it off the cover. Go under front wheelarch and peel back the lower corner and remove the torx screw that goes through the wing into the sill cover. Then just pull the cover out horizontally to remove it from its clips.
Here's the first view from the front of the car towards the back
Just in front of the back wheel
Underneath just in front of the rear wheel where the sill flanges have collapsed when jacking up
I like the photos. I have a 1999 S Type 3.0 and this has also suffered similar corrosion.
I guess the use of salt spreading on winter roads in the UK does not help. I wonder if Jaguar also skimped on corrosion protection?
Are you using old tool box/chest metal for your patches?
Ha, yes. Well spotted. The perfect thickness for that panel. Not for the one today though! Advantage is also that it has some protection on in the shape of powder coating. It all helps.
Hi Steve and Russ68.
Dont look under the covers! I did that once and look at the mess I'm in now!!!
Ill take it steady with the pictures.....
Today was weld up the steel that I had fabricated and make the bottom horizontal plate. This one.
And after 3 hours, here it is! Complete with all original holes and turned over lip on the big one.
As you can probably tell Ive welded on a right angle flange to keep the strength in that area when someone uses a jack there.
Weld that in tomorrow after painting iut on the inside with etch primer and blue paint.
Speaking of blue paint, the inside of the cavity was prepped, etch primed and painted blue. Looks good even though no-one will see it, and it will be covered in dinitrol 3125 anyway!
Even more welding to do tomorrow then, but at least it will be pretty in blue!
We don't have the same products in the states that you do.
Can you explain Dinitrol 3125 and KURUST?
I think KURUST is something like POR-15 over here.
A lot of rust and you fab sheet metal pretty good!
Thanks tbird6.
I've had plenty of practice!!
KURUST is a rust conversion liquid. Goes blue and black when rust is "encapsulated". Then you can paint over. Kurust
Dinitrol 3125 is a rust preventative wax that is sprayed on under high pressure form a dedicated sprayer driven from a compressor. DINITROL 3125 HS CAVITY WAX
Hope this helps.
Andy.
Hi Andrew where in the UK are you? Is this your main business ?
my s type r hasump some seriously rusty sills. Need them fixed or the cars off to the scrap heap.
I don't think Andy has been on the forum since late 2015.
If you open his profile and scroll down he has provided some contact info.
