S type 2.7 D dead need advice
Hi all,
I own a 2006 S type Diesel.
A new battery was enstalled six months ago.
The car was not driven for a week weeks, and when I tried to start it last week, nothing except a faint blinker and clicking noise, which I suppose was the alarm draining the last energy for the battery.
Here comes the problem, I dont have access to the boot as the lock is broken, and i always use the fob or the button on the dash to open it.
After some browsing on forums I tried the following tricks:
- I bought a 12v booster with a cigarette lighter cable, no luck there.
- I attached a c-tek charger to an empty unused fuse in the fusebox under the hood, no luck either.
- then I read about that emergency + acces point under the right weel cover, which i found, attached the charger there, no luck either, the charger doesnt detect any battery attached
- I used starter cables to attach another battery to this + point and nothing happened either.
My question is, is it normal to get no immediate response whatsoever from the car , and should i leave that battery/charger attached to that + point for a while to allow charging, or might there be another issue?
Im out of ideas, except destroying the trunk what can i do
thanks for any ideas and help
As it will be a calcium lead alloy battery you will have to recharge for 20 hours. You will have sulphide build up on the plates which you can not get rid off. This will mean that the battery will never function to 100% again.
Check the voltage on the poles after it is charged to see if it is lower than 12.6 v. If so you will have to get a new one. You should be able to get it exchanged on guarantee as it six month old.
Hi all,
make sure you have a good - earth point when using the jump cables . really
if you have a good jump battery connected to a good earth point and the pos connected to the jump point behind the under guard then the boot/trunk button should work .
what about the center arm rest in the back seat , do you have the ski pack to reach through for the seat fold cables ? fold the rear seats that way and pop your boot .
the lock is too damaged after a break in attempt, i ve tried even looking for the steel wire behind the chrome plastic jaguar lid on the boot, but no luck there
i charged a new battery to full and tested it on two chargers, its at 100 % capacity, if the car would not react when attaching this to the +port under the wheel lining and a earth point, what could then be the issue
Finally after days of struggling we made it
- i took the lower backseat out completely , took out the sidepanelss and then unbolted the screws of the upper backseat , then had enough room to squeeze an arm in and to grab the stick that u have to pull to unlock the seatback to fold it, hurrraaayy...
- tested the battery , completely dead
- removed the boot carpet, removed the spare wheel ( all of it had to be taken out of the car thru the drivers seat door as the double locking didnt allow me to open any other door)
- took out the battery and replaced it by another charged one
Car started to beep and lights went on and it started without any effort
I tested the battery i took out and tried to charge it but the charger says the battery is a goner.. its a 6 month old varta battery ...
the old battery was in the shed for over six months was completely flat but started charging and was full in less than a day...
