S-Type 2000 Wheel size options
Fine.
Sitting higher has its benefits.
Another unrelated question I just remembered:
sometimes the transmission stick (gear selector lever) travel
is restricted from reaching the Park position by its housing,
only reaching Reverse position,
indicating that the connected transmission underneath it
might have rotated slightly.
Currently, shaking it a little side to side will usually suffice
to register it at Park.
What is the solution to this ?
The 2000MY (X200) jaguar was offered with 16" or 17" wheels ONLY.
Wheels and Tyres
Wheels
All wheels are alloy except for the space saver
wheel which is steel. The space saver wheel is not
available for USA, Canada or Mexico.
There are three wheel styles:
¥ 7 x 16 Classic
¥ 7.5 x 16 Dynamic
¥ 7.5 x 17 Sport (option)
Each wheel has five exposed wheel nuts which are
smaller than current cars at 19mm A/F
Locking wheel nut policy is the same as current
sedan vehicles.
Tyres
Two sizes - three types:
¥ 225/55R16
All season (NAS markets)
Summer (European/Rest of World)
Winter (accessory)
¥ 235/50R17
Winter (accessory)
Tyres for the European and Rest of World markets
Summer/Winter, are Pirelli.
The all season tyres are Bridgestone and for the
NAS markets only.
Tyre pressures are:
¥ 26/28 psi comfort
¥ 32/34 high speed or fully laden.
Wheels and Tyres
Wheels
¥ 7 x 16 Classic
¥ 7.5 x 16 Dynamic
sedan vehicles.
Tyres
¥ 225/55R16
Winter (accessory)
¥ 235/50R17
Winter (accessory)
NAS markets only.
Tyre pressures are:
¥ 26/28 psi comfort
The pre-facelift Sport was fitted with 18" BBS Monaco wheels on standard suspension. Sports suspension came in with the first facelift.
Actually, all later S-Type wheels fit the original cars too. Just have to have the correct tyre size to keep the rolling diameter and clearances correct. There should be no difference in ride height.
The last S-Types had the option of 19" wheels from the factory, which look too big to me on an S-Type. 18" looks just right. 16" feels slightly better and they are definitely noticably lighter.
That is hard to figure.
The JTIS does not work on any computer with software past windows 7, which ended back in the dark ages when the Huns invaded Saxony.
The bigger ones are probably heavier, which is undesirable in terms of handling & performance. Some people think they look better.
As the rim size goes up you decrease the sidewall so as to maintain the overall diameter and in turn that means a harder ride. Some prefer that.
Interesting. In Europe, 16" Dynamic wheels were standard on both prefacelift 3.0SE and 4.0SE. The 17" Sports were options on all. Both 3.0 and 4.0 Sports had 18" BBS Monaco wheels as standard but only the V8 Sports got CATS as standard.
free Windows Media Center for TV viewing/recording/playback etc.
(including encrypted CableCard content store/playback on HDD).
In addition, for educational or technical Database-based software
like JTIS, you have to find a way of installing DAO, which
I found to be non-trivial.
Fortunately some defunct TV software I owned from ATI had
an executable which specifically installs DAO
(Jet Data Access Objects).
Received 6,307 Likes
Thanks for clearing that up! ![Icon Confused](https://www.jaguarforums.com/forum/images/smilies/icon_confused.gif)
I have JTIS on W10.
I have JTIS on W10.
I am using Windows 7 64, which is the last version to contain
I'm not the guy to help with the install problems. Did you see this?
From this thread........... https://www.jaguarforums.com/forum/g...s-65926/page4/
I just did this a couple minutes ago in a Win10 64-bit system
I did it for x-type but should be the same regardless...
Downloaded JTIS21 X_Type.part1.exe and JTIS21 X_Type.part2.rar
Ran the part1.exe. It extracted files...lots of them.
It created a folder call JTIS21 X_Type and inside that folder was the dao350.dll
Copy the dao350.dll
Paste it into:
C:\Program Files (x86)\Common Files\microsoft shared\DAO
(you'll probably see a dao360.dll there already...that's ok)
Click your start button....go to Windows System...when it expands RIGHT-click on Command Prompt and choose Run as Administrator.
you can probably copy and paste this, but.....run this command in that command prompt window:
C:\Windows\SysWOW64\regsvr32.exe "C:\Program Files (x86)\Common Files\microsoft shared\DAO\dao350.dll"
Now go to your JTIS entry in your start menu and run it.
I think in order to see some of the photos, you'll need to install the windows help system which I haven''t done yet, but this DID show me the diagrams and procedure when I looked up changing a starter.
I'll look at installing the help system, but that should get you started (pun intended)
Copy the dao350.dll
Paste it into:
