S-type 3.0 crank sensor
Hello all,
Does anyone know what the static resistance on a healthy (or new) OE crankshaft position sensor should be? I believe part # XR829578.
This car has had what I believe to be an aftermarket version installed. Signal is weak (<.5V p-p) at idle and measures 285 ohms. This seems low to me.
It starts and runs but sets P0335.
It is an '03 V6 3.0 S-type; last 6 of VIN: M91004.
Received 2,623 Likes
PatrickO (03-08-2016)
This is where it gets tricky.
I did indeed replace the sensor. I used an aftermarket sensor sourced through a local parts store. The price was $24, BWD brand. OE from Jaguar is $200.
The $24 dollar version is listed as fitting Ford Taurus (similar engine) and cross-referenced to also fit 3.0 S-type. This is why I would like to know resistance value of an OE sensor. I suspect the Jaguar system uses a different value but I'm not sure. 285 ohms seems low to me.
This is a customer's car and I should know better than try to save him money but I usually try.
If I can be sure an OE sensor will fix it I will certainly use one.
Connections appear good but it is not so easy to access PCM to verify continuity but running engine with sensor disconnected indicates that the signal is reaching the PCM.
Thanks for your input.
Timmy Gibson
02-15-2016 11:46 PM
Timmy Gibson
02-12-2016 06:44 PM
car5car
02-07-2016 12:51 PM
rcbarbier
01-30-2016 05:20 PM
MHrusovsky
07-08-2009 04:54 PM
