S-Type 3.0l v6 DSC problem
Can any one point me in the right direction, My S-type has had a dsc proble with fault code " c1288 Primary Pressure Transducer Circuit Failure" . if someone can at least help with what this means and where do i start in fixing it .
thanks
chris
thanks
chris
Welcome to the forum Chris,
C1288: Primary brake pressure sensor circuit fault
The bad news is DSC Control Module calibration is required when the fault is repaired and the DTC is cleared. MIL will flash to indicate that configuration is required. Delaer level diagnostics are required for this.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see.
In return you'll get a proper welcome and some useful advice about posting to the forum.
n2audio
17
10-09-2015 10:53 PM
goges
10-05-2015 04:53 PM
jessejamestw23
09-26-2015 03:57 PM
