S type 4.2 V8 2004
S type 4.2 V8 2004
I hope someone can help me i have 3 niggleing faults on My S type 4.2 V8 2004 and although they do not interfere with the general running of the car they need to work because they are there.1)A/C i had it regassed but still wont work i heard someone mention something about flaps behind the dashboard.? 2)The rear parking alarm sort of works but instead of going beep beep beep gong faster as you approach an object it just has one continuous beeeeeep then stops?3)My offside door mirror (passenger side) has stopped working electrically but can be adjusted manually, The drivers side mirror works fine. Please any ideas will be most welcome.Thanks.
Received 2,677 Likes
1)A/C i had it regassed but still wont work i heard someone mention something about flaps behind the dashboard?
See if this helps:
https://www.jaguarforums.com/forum/s...ol-how-185002/
Specifically, pay attention to the simple tests in post #2. It's possible the AC side of the system is working properly, but the heat is stuck on.
The "flaps" behind the dashboard? Do you mean the doors that direct airflow to the different outlets? They don't control the heating or cooling, only where the airflow is routed. Those doors are fairly reliable. To test them, turn on the engine and manually select the fan to high speed. Play with buttons for the defrost, vent, floor, etc., and see if the airflow responds accordingly.
veffremov
Audio/Visual Electronics
09-04-2018 09:27 AM
Boomslang
04-26-2013 01:32 PM
dc2kid
02-10-2012 04:35 AM
