s type audio/bluetooth
here is a question... what if under my center console I have a motorola piece that holds a phone however the phone is not present?
I went on jag's website and it says I should have it based on my vin however I cannot find the blue tooth when I look for it with my blackberry.
Same BT questions here; I'm considering buying a 2006 (MY2007) S-type which seems to have the Microphone installed as mentioned here before.
However, when I press the telephone button it says "NO PHONE".
So I guess this has some sort of prewiring (also the microphone), based on VIN it has "Telephone prep pack B".
The dealer is unfamiliar with the car and it is located quite far so I can not check physically this again.
But someone mentioned that if it has the Microphone then it will have the bluetooth as well...is this so and any easy way to test (if I ask the dealer)? Only thing I did was to note the Mic and that by pressing the button it said "NO PHONE"...
Thanks!
Thanks!
Erwin,
Microphone doesn't mean anything. All the cars were pre-wired, early ones had the microphone integrated into the center light cluster, but it didn't work well and didn't have enough volume. Later, Jaguar moved it external to the light cluster. Also possible that a previous owner took the PSE and BT module out of the car before selling it.
I admit to being on of those owners, as the buyer was just killing me on the price and didn't care about the BT capability, so I pulled the PSE and BT modules out and sold them separately.
The only way to determine for sure, in the absence of an IDS system at the dealer is to remove the cover on the LHS of the trunk and physically look for the PSE in the electronics stack. Also check for the BT module in the armrest. If both are present you should be in good shape. Finally, I had the old Motorola analog phone in my '04 XJ8. The PSE was an early revision (AA) that appeared to work fine when I upgraded to . Jagaur say AD or later for the BT module (IIRC, it was 3 years ago). Having an older phone in the car will also make the upgrade easy, i.e. no visit to the dealer to add the PSE to the fiber-optic loop.
#28
Many thanks for the insight! So does the prewiring mean that it has the mic and the connections, and the kit required is then:
- PSE (what is this actually) in the trunk
- BT module in the armrest
Anything else?
if I can find these items then only thing left (provided I was able to install them successfully - should be if prewired?) is to program the car to "find" the BT attached to the fiber optic ring?
Anything else?
Erwin,
My experience with Jaguar telephone equipment has gone from having the first Motorola StarTAC in an X300, through later Motorola analogue in an early XJ8, dedicated handset Bluetooth in an XJ8L to factory fitted Bluetooth in my current XK8. By comparison, my last XK8 had no factory phone installation and I fitted aftermarket Parrot.
If my present Jaguar hadn't had Bluetooth fitted, there's no way I'd go to the major expense of retro fitting. Jaguar are always behind with telephone technology. The compatible phones are limited and the biggest drawback is you can only pair one phone at a time. Two drivers with different phones have to go through the pairing procedure each time.
Just my thoughts.
Just my thoughts.
#31
Anything else?
Anything else?
BTW it is hard to find the PSE. Look at ebay in UK, there seem to be more there. Also go to the dealer for the BT module. They are very rare on the used market and it is easier to get that and the microphone from the dealer, IIRC it should be ~$250 for the pair. I got mine from George at Nalley but I don't think they are in business (as a Jaguar dealer) anymore.
#32
#33
Well that was an interesting point about multiple blue tooth vehicles trying to pair to the same phone! I thought my unit had failed because it stopped linking to my phone and then I discovered that someone else had paired their phone to it! I guess you can't have multiple phones paired to it. But then only one should be linked to one time, therefore a pairing operation would have to be repeated.
#34
Hi all
I just bought a 2004 x type. there is a telehone panel with all the numbers etc... When I press the phone on the dash it states "no phone", when I press it on my steering wheel it mutes the radio. Do I have a bluetooth capability so that I can use my cell phone or not? how can I know that
Thanks you for this genius forum and your help
Marc
Marc
#36
#37
I did exactly the same. Got a Garmin 1390LMT for $98, including lifetime maps at no extra cost and Bluetooth pairing to my old Nokia cell-phone for hands-free calls with voice command. Couldn't be easier, couldn't be cheaper, sits almost out of sight over the ashtray and powered by a USB cable from the cigarette lighter. The Jag Nav/BT/phone setup seems medieval by comparison, and the COST!!!
#38
Gentlemen,
I'm a lucky
- I've got a Jag with fully functional bluetooth phone.
But that is not enough for me - I want an AUX input.
I know everything about ACM, and its price.
My question is - if I replace stock stereo with some aftermarket one that fits and looks good (are there any at all???) is there a chance that it will work with the stock bluetooth system, and I will be able to control it from the wheel?
I'm a lucky
![Icon Verzsilly](https://www.jaguarforums.com/forum/images/smilies/icon_verzsilly.gif)
#39
Hi all
Marc
Marc
#40
KarimPA
09-12-2015 08:15 AM
KarimPA
09-03-2015 07:32 PM
