S Type battery drain
Old 09-08-2013, 11:07 AM
gr1's Avatar
gr1
gr1 is offline
Originally Posted by drun
I had this same issue and my battery drain problem was a faulty ignition switch, (the back half can be replaced without removing the key portion). These are a result of heavy keychains that leave the switch partially on and it burns the contacts.
There was a thread on here quite a while ago with a reply from a dealership mechanic stating this was so frequently the cause that they automatically changed out the rear of the ignition switch first.
I put new battery on so far so good 1 week in
Old 12-28-2013, 03:33 AM
gr1's Avatar
gr1
gr1 is offline
Default s type2.7 battry
Originally Posted by gr1
did you find the fault I also think I have a drain as iv had the battery tested its ok. without any warning in two week ago my battery was flat jump start from breakdown van ran ok till 2 week later same thing.can any1 help
just an update having visited 3 garages all told me battery ok. after one month still going flat so replaced battery. 4month on no problems
Old 12-28-2013, 05:39 AM
JagV8's Avatar
Received 4,531 Likes on 3,941 Posts
Sounding good! Thanks for the update.
Old 12-28-2013, 10:22 AM
clubairth1's Avatar
Received 2,366 Likes on 1,864 Posts
The battery turns out to be the problem for a lot of these weird electrical problems.
Glad it worked for you!
Old 11-24-2022, 02:32 PM
Matrix1906's Avatar
If there was a drain, replacing battery may have fixed it, if low battery voltage was triggering modules and such. But if the drain still exists, replacing battery only masks the drain, requiring more days to elapse before the car will not start. I would be interested in knowing does car start after several days of sitting.
Old 11-24-2022, 04:27 PM
S-Type Owner's Avatar
The last post to this thread was made just shy of nine years ago... The OP has not posted to the forum in roughly three years, so unless you are very lucky, a response is likely not forthcoming.
Matrix1906 (11-24-2022)
Old 12-16-2022, 01:17 AM
GMoney1967's Avatar
I just recently had my 2002 S-Type broken down for 4 months. The battery was going flat. The PATS disabled the engine. And on the couple of occasions that I got lucky and magically got it to start, it wouldn't shut down. I finally found out what the problem was. In the trunk/boot look for a fuse called the transit relay fuse. Remove it and throw it as far away from the car as possible. Look it up and you will see what it's for. I scratched my head for 4 months and hopefully I can save you some trouble.
  #28
Old 12-16-2022, 09:58 AM
clubairth1's Avatar
Replacing a battery will not fix a battery drain. You need to troubleshoot the source of the current drain.
Old 12-16-2022, 10:23 AM
JagV8's Avatar
look for posts on
quiescent current
Shawn Svacha
11-04-2019 02:47 PM
TXJagR
03-12-2016 11:12 AM
dcvickers
09-02-2015 06:14 PM
Thia
09-01-2015 10:36 AM
stanjag
08-30-2015 10:35 AM
Quick Reply: S Type battery drain
