s type cooling system refill
RE: s type cooling system refill
usually a good vacuum pump or pressure bleeder works perfect..but if you dont have any.. you can let it sit over night or you can close everything except the rad cap .. and cover it with your palm.. (engine off ). and with the other hand squeeze the top rad hose.. couple times then release other hand.. to let air out.. may take several times .. after about 10 minutes shud be good..
BrentGardner
28
04-26-2024 04:08 AM
stanjag
08-30-2015 11:35 AM
