S type fuse diagram
Received 3,907 Likes
james, check fuse #20 (10 amp) in the primary fuse box and also fuse #29 (5 amp) in the primary fuse box. Both of these feed power to the wipers. You will also need to check fuse #8 (10 amp) in the rear distribution box. The cover should show you where each of these fuses are based on number. If you need more help, I will give you a detailed location of where each of these fuses are located.
