S Type LSD? Lincoln LS Install
Old 03-19-2013, 08:42 PM
bfsgross's Avatar
My brother's infantry company snuck into Cambodia whilst supposed to be in Nam.
  #282
Old 03-20-2013, 03:27 AM
Received 4,458 Likes on 2,427 Posts
Originally Posted by bfsgross
Cambo, would that be the same Quaife as the STR.
Fixed that for you
Yes the QDF3W is the one for the STR, as well as the X350 XJ's and early X150 XK's.
From what Tom told me, if you have an early model the modification to the housing is only necessary if your diff has been replaced with a new unit, which had a redesign at some stage.
  #283
Old 03-20-2013, 09:42 AM
bfsgross's Avatar
So 2003- S-Types need modification to the diff.?
  #284
Old 03-20-2013, 10:14 AM
Why don't you write to him and ask him tom(at)tljaguar.co.uk
bfsgross (03-20-2013)
  #285
Old 03-27-2013, 10:08 PM
Tijoe's Avatar
I picked up my Mark VIII carrier assembly today. It is fitted with a Torsen T-2R 31 spline differential and 3:55 gears. (Remember, I've swapped out my trans. with a 6 speed, so I wont have the STR/Trans ratio problem)
Attached is an image of the Unit. When I finish welding new carrier mounts on the Donor sub-frame, I'll post more images.
Also, Has anyone come across replacement subframe rear differential bushings? Perhaps made out of Polyurethane?
Attached Thumbnails S Type LSD? Lincoln LS Install-img_3893.jpg   S Type LSD? Lincoln LS Install-img_3885.jpg
  #286
Old 03-27-2013, 11:30 PM
bfsgross's Avatar
Joe, you are using the Ford 5 speed gear box?
  #287
Old 03-28-2013, 06:42 AM
i think hes using a tremec 6 speed, tr6060?
  #288
Old 03-28-2013, 08:56 AM
OK I just picked up the XJR from my mechanic...the Quaife is in!
So, QDF3W from TL Jaguar tom(at)tljaguar.co.uk was £695, another £195 for the bearing and seal kit, £80 delivery from UK to Switzerland. Those are export prices without tax. I'm waiting for the bill to come from customs...
This is what Tom sent me.
This is what the stock open center looks like inside the housing.
Here the stock center next to the Quaife. Outer dimensions the same.
Here the Quaife installed in the housing. Fits in like the original center, no grinding, no modification, it just slipped in like the original unit.
Bolting the finished diff back in. No problem!
So how does it drive? Well as it turns out we had a big dump of snow last night, and this afternoon it's warmed up enough for a steady drizzle of rain. It's wet. The car is back on the 20" summer tyres. And it's very, very driveable in these slippery conditions. I haven't had much of a go with it yet, but my mechanic had a long road test & said "it's awesome man" so I think we are on a winner.
As it turns out, it was a very good idea to go for the bearing & seal kit. The pinion bearing was pretty badly scored and would probably have started making a lot of noise fairly soon. Only 153'000kms / 93'000mi on them...
Looking at the pic with the Quaife installed in the Jag housing, there is so much space in there i'm really wondering what the problem is to fit an 8.8" clutch LSD in...grind what exactly????
Attached Thumbnails S Type LSD? Lincoln LS Install-sdc13306.jpg   S Type LSD? Lincoln LS Install-img_7220.jpg   S Type LSD? Lincoln LS Install-img_7242.jpg   S Type LSD? Lincoln LS Install-img_7256.jpg   S Type LSD? Lincoln LS Install-img_7269.jpg
The following 2 users liked this post by Cambo:
GT42R (03-28-2013), Michael Star (03-28-2013)
  #289
Old 03-28-2013, 10:06 AM
Interesting look at the interior of our stock pumpkin... sounds like an awesome upgrade, although price is about the cost of my OS GIKEN setup in my other car, and that's a far superior clutch based diff... still, glad there is an option out there for us, and that you're the first I've seen post details up on here of the quaife, appreciated, price isn't too, too bad I suppose...
  #290
Old 03-28-2013, 10:14 AM
bfsgross's Avatar
Default Quaife
So Joe, the Quaif fits into the STR without grinding?
  #291
Old 03-28-2013, 11:55 AM
Robert Page's Avatar
Top Man Cambo let us know how things go.
  #292
Old 03-28-2013, 01:06 PM
Tijoe's Avatar
TR6060 - 6 speed
  #293
Old 03-28-2013, 02:14 PM
bfsgross's Avatar
OK. Does the Quaif fit the STR's case without grinding (direct fit)?
  #294
Old 03-28-2013, 02:57 PM
Tijoe's Avatar
I was looking at the picture of the Quaife installation and one thing stands out. There is only one bearing clamp on the Left side! I assume that the second bearing housing is pressed into the carrier housing. Makes me wonder how strong the housing is in that area.
  #295
Old 03-28-2013, 03:36 PM
Yup, noticed that too,
I'm guessing the bearing's outer race/cone is pressed into the housing, the bearing itself is pressed onto that end of the differential, then you load the assembled diff in with that bearing end first, and drop the cap side in next, bolt down the cap, and done,
agreed, not very robust looking... but a bit simpler too...
  #296
Old 03-29-2013, 09:35 AM
Staatsof's Avatar
Thanks for mentioning this:
Product
This looks more suited to racing though.
What's the longevity of the clutch in this unit compared with the Quaife's design?
Some on here are probably more interested in that level of tuning whereas I just want to add a decent LSD to the car. Hoping to hear some feedback from his Ring experience. That's a serious track.
Any further thoughts?
  #297
Old 03-29-2013, 10:05 AM
Did you ask Tom? He will know.
  #298
Old 03-29-2013, 10:12 AM
Staatsof's Avatar
I'm confused I thought in your most recent post you said it DID NOT require any grinding?
Are we talking about the same diff or does yours have a different style case?
  #299
Old 03-29-2013, 10:17 AM
avos's Avatar
Received 1,068 Likes on 761 Posts
Have had the quaife before, and although its a great diff, I much preffer a good clutch type one, and drive now the OS Giken TCD version. Its a fantastic diff, and I doubt I have ever replace the clutches due to its design and number of plates. Its a diff just as well for street and will do great for track.
  #300
Old 03-29-2013, 10:24 AM
Staatsof's Avatar
They don't list any Jag but I guess a call might answer that?
Quick Reply: S Type LSD? Lincoln LS Install
