S type mechanical issue?
Guest
Posts: n/a
![Unhappy](https://www.jaguarforums.com/forum/images/icons/icon9.gif)
Hi all i just purchased a 99 4.0 V8 S type two weeks ago and noticed an ever so slight miss in it. Figured it was just because it had not been driven in over a year till it started to get worse. And then it started to really miss fire and chug with a detonation type sound on light throttle. Changed the fuel filter and spark plugs, filter was filthy but no help. Then to mechanic for a diagnostic check where he said it needed new coil packs and platinum spark plugs. That did not work either and he did further checks to inform me that it's probably not the coil packs but rather some bent exhaust valves??? He says that it could have backfired at some stage which can disrupt the timing chain tension which will damage the valves.....?? Says it will be about $5000 in repairs. Anyone know about this problem???
Guest
Posts: n/a
Received 6,304 Likes
Guest
Posts: n/a
Just a crazy thought. The early 4.0 engines had a reputation for bad timing chain tensionors. That would cause the timing to be off. If the timing is off wouldn't that cause a valve seat issue. I agree with Norri. The 4.0 is a real strong motor and something as severe as bent valves doesn't sound likely.
Guest
Posts: n/a
X_Type_South_Africa
12-09-2015 05:37 PM
stanjag
08-30-2015 10:35 AM
SingBlueSilver
08-27-2015 02:20 PM
