S-Type not cooling at idle
Old 04-29-2013, 03:37 PM
chromedragon's Avatar
Default 2003 S-Type with no AC
I had the same problem being described: At idle, the AC was gone. At highway speeds, it returned.
As time passed though, it got worse to where it stopped producing cool air even at highway speeds or just for a few minutes at a time. Eventually I ended up with no AC.
I would like to get a whole kit, if that's possible. I have not found one yet.
If anyone knows where I can get like repair kits, condenser, compressor, hoses, etc. please let me know.
Old 04-29-2013, 04:50 PM
tbird6's Avatar
With 169K miles on your car I think the A/C compressor has done its duty. I found Chinese made brand new compressors on EBay for very good prices. I got a compressor, filter/dryer and the expansion valve with no core charge for under $250. Including shipping.
It's been 6 months and several thousand miles and everything is working good.
Old 07-23-2013, 09:20 PM
hinsonb's Avatar
I have the same issue. My ac works fine at 1500 and above but isn't as cool at idle. I want to try the valve and spring swap but do you have to evacuate the system first?
Old 07-24-2013, 09:02 AM
TonyX's Avatar
Yes. In this order:
1 - evac the R134a from the system
2 - do the TSB: take out back plate and swap positions of the spring and valve
3 - evac and refill with right amount of R134a
Jumpin' Jag Flash (10-29-2013)
Old 07-24-2013, 04:10 PM
hinsonb's Avatar
I saw the thread on doing this and that you need a vacuum pump and guage manifold but where does the r134 go when you do this?
Old 07-24-2013, 05:16 PM
tbird6's Avatar
If you have the proper A/C recovery machine the R134a goes in there.
If you mean where does the 134a go when refilling. Then you charge thru the A/C gauge manifold into the low side port.
Old 07-24-2013, 06:33 PM
hinsonb's Avatar
I don't have a recovery tank so I guess I should just have someone evacuate it for me! I am not an ac guy but the way the thread made it seem was all you needed was the pump and the guage so that's why I asked the question. Thanks for the insight.
  #28
Old 08-12-2014, 07:02 PM
Brandan003's Avatar
how can i evacuate the system without a reclaiming tank? a ac tech said that i barely had an freon inside, is there a way to release it into the air? (shame on me i know ),
Old 08-13-2014, 01:35 AM
JagV8's Avatar
Received 4,531 Likes on 3,941 Posts
(On a previous car) I got a mobile a/c guy to do it but any shop can empty the system. Then I repaired the system and had a prolonged vacuum held and finally system refilled. It's not magical and also isn't costly.
Mac Allan
10-27-2015 04:49 AM
captbob73
10-24-2015 05:49 PM
ssshield
09-24-2015 08:29 PM
NTL1991
XJ40 ( XJ81 )
09-20-2015 06:22 PM
Jaguar_libra
US Western
09-09-2015 04:20 PM
Quick Reply: S-Type not cooling at idle
