S-Type R 2004 Radiator Cooling Fan Runs After Switchoff
#61
Received 6,339 Likes
sunshinesdad (10-04-2017)
#62
Copy of Bill
Hi Mikey, SteveP10
Here is copy of bill. I had 15 Year service done at same time.
Thee overheating part at the bottom was 2000 Euros approx.
The parts cost shown do not include VAT/Sales Tax which is 20%, added at the bottom
The Water Pipe replaced (Tuyeau de Sortie) has part number JLM21896
See:-
https://parts.jaguarpalmbeach.com/p/.../JLM21896.html
They replaced the "Couvercle de Thermostat" - Thermostat Cover - part AJ84255 - is this the Thermostat Tower you mentioned Steve?
See:-
https://parts.jaguarpalmbeach.com/pr...chTerm=AJ84255
Your advice steered me in the right directions, particularly making me aware of the damage to the alu Jag STR engine causable by overheat!
Thanks - D
See:-
See:-
Thanks - D
#63
Thanks for the info.
I don't know much about JLM21896 though it's very expensive
e.g. Water Outlet Pipe 4.2 Litre V8 XKR Supercharged JLM21896 | Jaguar XK8 and XKR Parts and Accessories
#64
sunshinesdad (10-05-2017)
#65
Expensive but no choice
Of course Jag parts fitted down here in France by Jag dealer are almost certainly at a hefty premium over UK prices.
I'm sure that an independent garage would not have replaced that pipe, and the overall repair would have been less than a third of the Jag dealer price.
But I had no choice since I did not feel able to do the repair myself, and there was no viable independent nearby
#66
#67
Received 2,266 Likes
I've searched everywhere and can find no reference to part no. JLM21896 being replaced as a routine part of thermostat change. It does not seem to have a remarkable failure rate either so it's a bit of a mystery as to why the dealer chose to replace it.
In any case the car is up and running now so it's all water over the thermostat I guess.
#68
From the pic in the link, it doesn't seem like a similar circumstance, but who knows? There is an aluminum fitting in the 3.0L cooling system that attaches to the intake manifold, and has a short hose that connects to the upper rad hose assy, just behind the infamous "tank turret." Per Jaguar, the service part for the HOSE is the entire assy, including the aluminum horn/fitting for $123 or some such. The hose itself can be made from cutting what you need from a nominally $8 radiator hose. As I said, I don't see a hose attached to the part in the link, but perhaps they've employed some similar trick?
