S Type R- aftermarket wheels- 19's or 20's?
Old 04-15-2011 | 06:28 PM
qwiketz's Avatar
Default S Type R- aftermarket wheels- 19's or 20's?
Hi guys. As you know two of my wheels are screwed and 1 tire is shot. I'm thinking of going with a set of Stern St11 wheels. they're dirt cheap and look okay. The question is, should I go with 19's or 20's? I have lowering springs on my car. I will keep the staggered setup with 245's up front and 275's out back.
Photos of cars with 19's or 20's would be greatly appreciated!!!
Old 04-15-2011 | 07:07 PM
DrJsl22's Avatar
Personally, I think the 19's are perfect, but here are some of each.
19's
20's
oaklandray (12-10-2011)
Old 04-15-2011 | 07:16 PM
phaelax's Avatar
I think 20" would look too big and the lower profile tires might hurt the ride comfort, but that's just my opinion.
Old 04-15-2011 | 07:56 PM
qwiketz's Avatar
I just got off the phone with a coworker running a 245/30/20 set of wheels and he hated them. He broke several wheels due to hitting pot holes. He suggested I go 19's instead.
The photo above is awesome. That car is the same color as mine too. That looks perfect. Now to decide on silver alloy colored wheels or black with polished lips. My windows are tinted like that car's.
What specs/offsets do I need to buy? Stern make an 8.5 and 9.5 in my size so I'm in luck there. I just need to get the offsets straight.
Old 04-15-2011 | 08:10 PM
qwiketz's Avatar
crap, they only make the st11's in 18"X8.5 in a 5x108. Bummer.
However, I just called a wheel place and they said that they would re-drill the holes to work with my setup. I guess they would get a 5X112 and move the holes 4mm some how. So, for $100 they'll do this.
Old 04-15-2011 | 08:49 PM
qwiketz's Avatar
anyone know what offsets I need on a 8.5 front and 9.5 rear?
Old 04-15-2011 | 09:31 PM
qikcat's Avatar
That STR with the 19" looks sick! Now aftermarket wheels are on the list!
Old 04-15-2011 | 09:59 PM
H20boy's Avatar
I googled it for you and found this website... Wheel Fitment.eu PCD Jaguar S-Type - the largest online database with PCD, Offset and Center Bore date for almost every car
if you find another that says the same, it must be true! You could take a digi caliper and measure it yourself...only sure way to know, right?
Old 04-15-2011 | 10:20 PM
jag79's Avatar
I say go with the 20's
Not b/c I have them on my STR that is already lowered by Arden springs
Attached Thumbnails S Type R- aftermarket wheels- 19's or 20's?-thebeast.jpg
Old 04-15-2011 | 11:16 PM
qwiketz's Avatar
bummer, the pic isn't working...
Old 04-15-2011 | 11:27 PM
pokey's Avatar
What/where is the shop that will do the re-drill for you?
Old 04-16-2011 | 12:57 AM
jag79's Avatar
..sorry about that, don't know why it didn't work the first time but now its up and working...
Take care.
Old 04-16-2011 | 09:51 AM
Scaaty's Avatar
Jag79 Hey, that looks great! I have the same year and color and now wish that I would have gone that route when I replaced my tires recently. Lowered and 20's...great look and it fills the wheel well gap nicely....any clearance issues at all? Do you have any other performance mods?
jag79 (05-31-2012)
Old 04-16-2011 | 10:01 AM
jag79's Avatar
Thanks Scaaty for the compliments . I have Mafioso's Custom Air Intake, K&N drop in, Full exhaust Mod with HI Flow Cats and Magnaflows with 4" tips and lastly Arden lowering springs kit. Hopefully later this year I'll do the 3lb SC pulley upgrade with the low temp thermostat.
As for clearance issues and ride comfort, no problems at all(knock on wood) Having the Arden springs over the H & R springs gave it the perfect clearance and covers the wheel well very nicely when lowered with the 20's since H & R drops it down a little more lower.
Take it easy bro.
Old 04-16-2011 | 10:59 PM
qwiketz's Avatar
One of the companies I called for the wheels said that. I'm new to this stuff; I'm not sure if that is common or not. The 4.5 mm is less than .2 inches
Old 04-17-2011 | 02:35 AM
08Z06's Avatar
I am about to buy these 19" Coventry Hornets:
They are made specifically for Jags
Old 04-17-2011 | 11:09 AM
androulakis's Avatar
Those will work fine on an STR i actually saw on on the Manheim website that had them on it in the south. Are you going to be getting rid of your barcelonas?
Take care,
George
Old 04-18-2011 | 10:17 AM
qwiketz's Avatar
It says the s type is 50mm offset. Is that the same for the s type r or does it not matter?
I just need to figure this out and then I have to figure out what is the best fit.
Old 04-18-2011 | 09:30 PM
qwiketz's Avatar
Alright, so I looked into this a little more. I found on one website the specs for the S type R:
2004 Jaguar
S-Type R
Bolt Pattern: 5x108
Center Bore: 63.9
Hardware:12x1.50 Lug
Offset:
Front: 34-42mm
Rear: 40mm
However somewhere else I saw that the offset listed at 60mm. And on the coventry website, I saw this:
front 42mm
rear 42
Should I go off the coventry website since they market wheels specifically for our jags?
Also, update... I found my wheels in a 19" 108 pattern, but only in the front size:
Stern ST11 Hyperblack Wheels 19x8.5 Boltpattern 5x4.25 (5x108) Offset 38 Hub Bore 73 Partnumber ST1185950838HB
they do have the 5X114.3 in 19x9.5" with 48 offset, but I'll have to have the wheel bolt pattern modified to 108 from 114.3. They make a 5X112, but it only has 25 offset.
So that's where I'm at currently. This is kind of a pain to figure out but it should be worth it in the end.
Old 04-18-2011 | 09:40 PM
Docuzzie's Avatar
I forged makes rims to order that fit the 5x108 bolt pattern of the Jaguar. They're cheaper than HRE's and exceptionally good quality
iForged Performance Wheels - The next generation in forging technology
Quick Reply: S Type R- aftermarket wheels- 19's or 20's?
