S-Type R Brake Vibrations
Hi, my brother recently picked up an '03 S-Type R with new pads but the same rotors. I was driving it yesterday and I was braking from around 50 mph and the brakes started vibrating violently and the wheel shook like a wheel was coming off the hub. It also occured from slower speeds when the brakes were pushed hard. High speed braking was nearly impossible due to the wheel almost coming out of my hands. I read a TSB on here that was very helpful (TSB 20610) and I'm hoping it will ensure that the brakes on his car will be replaced so it doesn't shake violently under braking anymore.
Any insight on those who have had the same problem with their S-Type R?
You may have bad rotors, tires or tires need to be balanced.
1st, check tire pressure, and make sure none of the rim weights fell off.
2nd, rotate tires to verify that it's not the tires...front to rear....rear to front...
3rd, inspect rotors for cracks, and possibly out of round condition...(will need a gauge)
Finally, inspect the brake pads to ensure they have seated correctly.
Good luck
Good luck
The fornt and rear tires on my 03 str are different sizes so you really can't rotate. I did read service letter to Jaguar techs that also says that the suspension can be the cause of vibration during braking and reccomends that if new rotors and pads don't work check the suspension. I too had a slight vibration of the stearing wheel when driving strait but when they fixed the squeaking in the rack it went away. Your problem sounds a lot worse then anything I've experienced.
Good luck.
Good luck.
hen555
09-07-2015 11:13 PM
