S-Type R High RPM Restricted Performance
Exhaust manifold leaks are NOT vacuum leaks. They only cause noise because at that point the exhaust is under pressure and not vacuum. So you will gets noise which usally goes away or at least gets quiet when the engine warms up and the exhaust manifold expands with the heat. You possibly could get an O2 senor code if the crack is large enough to let in air but I think that would be a stretch.
The V6 is well known for vacuum elbow problems but not the STR.
Those types of problems should not give a DSC error. You should have got the standard P0171, P0172 type stuff?
![Talking](https://www.jaguarforums.com/forum/images/icons/icon10.gif)
The confirmed issue was the Bank 2 cat. They were covered under warranty until 70k miles. BUT, I deeded to go with Magnaflow high flow cats instead.
I went with part # 59975 as most of you have here on the forums. I just picked her up from the exhaust shop that did the work and am very happy to say that she is running better then every before. I am planning to finish the exhaust with a Magnaflow x pipe (resonator will be removed) and new mufflers (dont know which ones yet).
I believe a THANK YOU
is in order for everyone that responded to this thread. It is great to be part of a community that can come together and help one another.
![Icon Beerchug](https://www.jaguarforums.com/forum/images/smilies/icon_beerchug.gif)
http://www.amazon.com/Magnaflow-5997.../dp/B000XQM3O2
I am sure that you can find them cheaper if you look around. I was in a rush to get them on the car so I went with Amazon.
#31
#32
05BLKSTR. the Borla's were purchased from Summitt Racing, part # BOR-40358 $99.95/each. These are 2.5" inlet/outlet. Summitt carries 2.25" Borla's too. Today, recieved the replacement Magnaflow hi-flow cat to replace the bank #2 failed Magnaflow hi-flow cat (CEL w/restricted performance.
#34
hen555
09-07-2015 11:13 PM
2004, car, drive, intercooler, jag, jaguar, jaguars, light, longft1shortft1, message, performance, reatricted, restricted, type, uprated
