S Type R Lower ball joint
As it is time to rebuild my failing front end I placed an order for new vertical links, 2003 Model Year STR, Gaudin Jag Parts has just informed me that the vertical link's for the supercharged model are no longer available:
"The following items have been discontinued and are NO LONGER available from Jaguar. I have checked the dealer network as well, but was unable to locate. P/N: C2C21656 ~ Front suspension, knuckle, Right P/N: C2C21658 ~ Front suspension, knuckle, Left."
You can imagine my joy that Jaguar has eliminated a common wear item, anyone have a current source for these specific arm's ?? Is the standard S Type not compatible with Brembo brakes ?
Thanks for any help you can provide!!!!!!
Paul
Paul
Found them at Welsh Enterprises, i asked about them apparently Jag dealers have been purchasing from them also as they have pretty much no stock elsewhere. $265 for the left unit and $275 for the right. Hope this helps some of you out, as this particular unit is used on the 03-04 S type R models years only and a few other models here and there I would think about getting them while you can. Just my .02
