S type R rattling engine noise HELP
Old 11-09-2012, 04:17 PM
Charliebearuk's Avatar
I'm kind of looking at 9.5 k due to the other items at the start of this thread abs leaking coolant temp not working full of fluid bald 2 tires front rotor shot body work 5/10 really been run rough ? And an 02 sensor
Old 11-09-2012, 05:44 PM
Bad Cattitude's Avatar
How much are they asking for the STR?
Old 11-09-2012, 06:24 PM
9500 sth Carolina buddy of mine
Old 11-09-2012, 06:25 PM
Just not sure how much to get the supercharge out and back in think a recon unit is 500 ?
Old 11-13-2012, 07:17 AM
Good morning
I've read the codes on this jaguar r P1346
P1646
P1000
The supercharger isn't giving any codes even though its rattling or part of it is,
Can anyone give me a list of things the check before buying a Stype R
Thxs
Old 11-13-2012, 07:28 AM
Originally Posted by bfsgross
Dang Charlie! Thought this STR was already yours? Ask to take it to a mechanic to spec her out. Have him remove belts, test bearings and with belts removed, start her up and listen. If you are able to pin point a problem and it's basically economical i.e. replace pulleys, tensioners, a/c compressor, etc. then use this as a tool to negotiate a fair price ex: $6000
Hi Mr Gross
Thanks for all your advise any more advise before a take the plunge thxs
Old 11-13-2012, 08:39 AM
JagV8's Avatar
Received 4,520 Likes on 3,931 Posts
There are existing threads about buying an STR so please just read them.
Buying one with known faults is not for the inexperienced (unless they have deep pockets and don't care about costs, although it would probably still be unwise).
  #28
Old 11-13-2012, 08:54 AM
Hi thanks for your advise the price is reflective in the condition ie abs leak have a replacement t module the rattle sounds like from a front pulley or nose come of sc unit and the low coolant even when it's full,
Old 11-13-2012, 09:12 AM
McJaguar's Avatar
Charlie, I think what we're suggesting is that the price does NOT necessarily reflect that. $9500 is not necessarily low enough when considering the problems that we're hearing about.
I'll tell you what: I've got an '03 STR that's VERY NICE. it's a solid driving car. No issues (except a squeal from a belt, which I'll rectify the moment my gatorback belt I just ordered arrives). Brand new tires. Integrated Video. silver/black. I'll sell it to you for $10,500. MUCH better idea than spending $9500 on a car with so many known issues.
yes, I'm serious. Let me know if you're interested.
  #30
Old 11-13-2012, 10:30 AM
bfsgross's Avatar
Charlie, mcjaguar made you a very generous offer. Otherwise, the rattling noise is likely a worn tensioner pulley bearing or another serpentine pulley bearing. The lack of info. and issues garnered so far from the STR your buddy is trying to pawn on you causes me to believe this is a $7000 STR that you'll likely invest another $3000-$4000.
  #31
Old 11-13-2012, 10:40 AM
Default Tensioner pulley surp pulley
Hi and thanks I'm still negotiating with
My buddy is the tensioner pulley and the serpentine pulley expensive to replace I d agree and if the cost to put this right is more than the 10k the other me will cost I will go for the one which isn't such a dog
  #32
Old 11-13-2012, 12:47 PM
bfsgross's Avatar
The parts are not too expensive.
  #33
Old 11-13-2012, 02:30 PM
Yes cool from what a remember was based on a ford mondeo a water pump is a lot cheaper than my disco will have to save up I took your advise and a jag specialist will be giving the car the once over before I buy here in atlanta
  #34
Old 11-13-2012, 05:48 PM
bfsgross's Avatar
That's a good idea Charlie.
  #35
Old 11-15-2012, 11:16 AM
Ok pre inspection show supercharge has rattle replacing rear engine mount rubber front wheel bearing expansion tank leaks
BrentGardner
28
04-26-2024 03:08 AM
Rupesh
03-25-2016 03:33 PM
jm717
02-27-2016 09:31 AM
Fraser Mitchell
10-01-2015 04:06 AM
stanjag
08-30-2015 10:35 AM
Quick Reply: S type R rattling engine noise HELP
