S Type R transmission cooler?
I've added a B&M stacked plate style tranny cooler to both my Jeep and Rover (they both tow a good bit and get off-roaded frequently) and I'm very happy with the results. Prefer the stacked plate design over the tube and fin style. I buy the kit that goes for about $65 from Jegs or Summit. Not very hard to plumb on the trucks. On the S-Type, I'm thinking right behind the grille might be a good spot.
I plumb them in circuit with the OEM in-radiator coolers. This helps get the temps up early on. Then the B&M helps stabilize the temps. Fluid path i use: tranny to OEM in-rad cooler to B&M back to tranny.
Not sure if adding one to an S-Type is really all that necessary though. Would need to install a guage first and gather some data.
