S Type Rust proofing
Next on my list is sill cover and floor cover removal. Then clean, treat and paint/ underseal.
Looking for recommendations on products, tools and materials needed. I have the use of a ramp in August so would like to take full advantage of it.
A
Also any links to threads you have created yourself.
A
Received 2,692 Likes
I have exotic vintage Italian cars and it always makes me cringe to see some of the rare cars Eurospares in the UK is parting out due to MOT issues. I don't drive my nice cars in the salt. PERIOD. Sometimes we have salt dust on the roads here for more than a month at a time too. It always amazes me to see people driving nice cars (anything north of $55K) in the winter here.
There's an awful lot of stuff to protect underneath on a modern car. A lot of the chassis and mechanical bits are painted but have such sharp edges that the paint is way too thin and that's where the rust starts.
I think the underside body parts still look pretty good on my STR but it's had very few exposures to direct salty water. Salt dust on the other hand is like EVIL! If I still had a lift inside a garage with 12ft ceilings I could address all of these issues much better. As it is I'm currently trying to deal with front frame corrosion that caused two cracks on my 99 Chevy suburban in the steering box area on both sides. The way the frame is constructed it has open, gaping punched holes in the front and on the sides where salty water can pour in. Not a lot of rust protection to begin with either.
Some people use these products:
Salt-Away Home Page
https://www.fluid-film.com/
I've put POR15 on a lot of tough spots as well.
I hope you have a lift for application.
SinF (07-25-2018)
I have used Hammerite on the underside of cars and on steel bike frames.
Two coats gives a good thickness of paint. Its not a pretty finish because it is brush applied and thick paint also it goes off fairly quickly.
It is robust and the plain black is available in gloss or satin.
You can't stop rust once its there, but you can delay it.
I drive Subarus in the winter, excellent all wheel drive system that combined with Michelin X-Ice tires makes winter driving manageable. I use oil-based, dripping, rust control spray (Krown or Rust Check) and it notably slows down the rust. If you start from new, it delays onset of rust by a decade or more. If you start after rust manifests you only buying extra couple years. The issue with rust is that some rust always results in more rust.
I think partial reason is they overspent and can't afford a winter beater.
hi
its worth getting the "Krown rust treatment" done
they strip the whole car and spray every where, they do a really good job, they also clean the car after
it also comes with a guarantee
have a look here Krown
and here on facebook https://www.facebook.com/krownuk/
cheers
Joe
cheers
Joe
