S-Type to STR suspension/brake upgrade?
Other then the obvious, which is to just buy an STR, what are the various differences between their major suspension components?
From best I can tell, to upgrade my 05 S-Type to an 05 STR suspension, I would need knuckles (all 4), front UCA, front sway bar, calipers and rotors, and the cable for the parking caliper on the rears.
That sound about right? Or are the LCA, rear control arms different? I am not wanting to get the CATS setup so I shouldn't need any of that.
I tried searching through the forum and around page 10 decided that the question was buried or not asked directly. If anyone can point me in the direction of a search term to use to find it I would appreciate it. "STR upgrade" and "STR brake" didn't return much, other then comparing 03-05 and 06-08.
To be honest, never heard of anyone spending that kind of money to alter a regular S Type therefore you are correct that a search would not return much. I've been on here for a few years and never saw a thread like you are looking for.
If I was going to do it (I sort of am, only slowly replacing 300C suspension components with those of the SRT8 300) here is how I would do it (how I am doing it).
Get a manufacturer's parts catalog. Don't use the generic parts suppliers. A trusted contact at the dealer works as well. For each component see if the manufacturer has different part numbers for the different cars. If it is a different part number, there normally is a difference. An example of this is upper control arms on my 300. The castings are the same for the SRT and C but the part numbers are different due to non-serviceable bushings pressed in to the arms.
I've owned both a base and currently a STR...Suspension isn't all that much better, in fact a lot of folks get the non-CATs bilstein struts/shocks...Brakes on the other hand are much better which also add to the "eye candy" or appearance when parked unlike the suspension...Be advised just in rotors weight you're increasing it by 25lbs and will probably need larger and heavier wheels which is going to equal a slower car...
On the other hand, as best as I can figure out from my parts list, I would be looking at around $3K to buy the parts. That's a mix of OEM, Aftermarket, and some used/salvage pieces. If I could find a wrecked STR somewhere to get the knuckles then that would probably be less.
I also understand that the whole argument about saving money in light of what I am doing is somewhat moot as well, but I would at least like to say that I entertained all options.
Thanks for all the input guys! I found a link to a 2000-2005 S-Type shop parts manual and have been mulling through it comparing numbers.
In that scenario, you now have an STR shell and no engine since you sold your S Type as well as the supercharged 4.2....
I'm really confused as to what you are trying to achieve.
If it is firming up the standard suspension and upgrading the brakes on a naturally aspirated V8 car, yes you are looking at $3,000 plus (using mainly used parts). Now the whole 6 speed manual thing throws me for a loop. That has been discussed here before and you are really opening up a can of worms. The only 6 speed manual trans ever made to bolt into the S Type was in the diesel cars in Europe. So, importing a transmission will be very costly... Then there is the cost to have someone build one off computer controls to just run the car... I wouldn't even begin to estimate what that would cost and even if there is a firm out there that could....
https://www.jaguarforums.com/forum/s...-engine-33719/
As of June of this year Tijoe has not updated / nor has he got the electronics sorted out....
Honestly, I'd love to see someone actually get it done. Yet to see it working...
So, I think buying a bunch of STR suspension and brake parts would be the least of my worries...
I could buy a mustang and get all that too, but then I would have to drive a mustang. The option doesn't appeal to me. Besides, I like the idea of a sleeper.
I have pretty much relegated myself to the fact that I am going to have to swap ECU's and do a ton of rework to get all the electronic parts of the car functional again. Some things I plan to just give up initially in order to simplify the ECU setup (like advancetrac). I think the real issue will come when I look into making the key fob, cluster, and all that talk.
I'm not sure if anyone considered the engineering difference, what is the weight of the 3.0 vs. the 4.2SC? I'd think that the ride height of a 3.0 with STR suspension would not respond up front that way it should. The rear, not so much. But the front rates would be very different.
