S-type Subwoofers in rear deck
#61
actually, i work until about 6 tonight, then the subs will be going in. Hopefully if my plan goes right, it will be quite simple and should sound much better the factory 6's.
Ultra 8's (1 pair) they seem to be higher efficiency and should work well in the free air enviorment of our vehicles.
I did run into 1 issue though, my sony camera has a duo pro stick in it, and i lost the adapter....so i have to stop and find one somewhere before i get home..........uggggg
#63
8's are installed, running off the factory amp. While the deep bass is present, the factory amp is having trouble keeping up. I have done some rta measurements, and now i need to wire in an aftermarket amplifier, to see what the differences make. Working on it a little at a time as i have been really busy for the past few months. I did take some pics of the 8's installed, i will get them up as soon as i can.
#64
I didn't feel real confident that he knew this car and it's quirks. What do you think about this?
What amp are you planning (or already did) to install with these speakers? Is a box underneath them required?
Thanks!
Craig
#66
my 2005 s-type came with an alpine set of 8inch woofers which did a good job in my opinion, but i wanted more thump in my base category.. so i disconnected the alpines, upgraded to a 12'' woofer and ported it to the inside of my cabin by building a custom box myself. I ended up spending $150 and 8hrs of work of a Saturday day
*(ill put up pics soon)*
#67
In my spare time I've been going back and forth with Mr Toby from www.Toby.com about replacements and he beloved he can help I just haven't had a chance to make it
Out there since they are local.
#68
#70
#72
What was the final outcome with this? Just bought an 07 STR & extremely disappointed in the sound system. I have the Alpine system with the "so called" subs and it's just not acceptable! I like everything except the distorted noise that comes out when I turn it up. All I would like to know is can I change just the factory subs with some other brand and have it sound better than the factory setup? I don't wanna get involved with changing the deck & amp.
2003, aftermarket, audiocontrol, deck, dql8, fiber, head, install, installation, jaguar, miami, optic, stype, subwoofer, subwoofers, type, unit
