S-type supercharger removal (with pics)
Sooooo the title says it all I took a supercharger out (doesn;t happen every day customer's don't like spending that kinda money) and I took pics along the way, specially because the only thread I found similar to this one kinda had limited pics (great info though) but you can't never have too much info and too many pics.
Here is the link: jaghelp.com: 2006 S-type supercharger removal
Any comments to improve the article will be appreciated. I will be putting it back together hopefully on Monday (if I get the parts) and posting the pics of putting it back together. I worked hard on this so moderators pls faq
The following 14 users liked this post by daxter1987:
Bad Cattitude (01-04-2014),
bluenoserules (01-07-2014),
Cambo (01-04-2014),
Carlg07 (01-10-2016),
Datsports (07-31-2019),
and 9 others liked this post.
Great set of pictures, daxter, thank you. I now have a much better idea of the steps involved and the complexity of this job. Short of a video showing your every action, this has to be as good as it gets.
Not having the experience that you and other forum members have, the only improvement that I can imagine would be labelled arrows identifying some of the bolt positions, hoses and other bits and pieces that you mention in each pic.
But that would double your work, and what is here already is much appreciated.
Depends on what you mean by day. As I put the pics together and described what I did I thought, damn it sounds much easier than it is. Specially the 5th bolt in the supercharger, I have small hands and thin arms, I don't see how anybody that's "average" would've done it... It took me about 4 hours to take it apart, but I was also taking pics and going slow to make sure I didn''t miss anything, and I am a professional mechanic with every tool available. All I'm trying to say is tht it looks easier than it is
Those weren't that bad. No I did not cut any bolts, the one that was a pain in the *** was the center one (you can see it on the last supercharger pics). the only other pain in the *** was the egr valve, I tried many was before figuring out the way I described. If I ever take one apart again it'll take me much less. Taking the EGR completely out makes it easy to access the side bolts.
Michael Star (01-06-2014)
Received 9,011 Likes
The following 2 users liked this post by JimC64:
daxter1987 (01-06-2014),
Vivid16 (12-25-2019)
Not sure about any extra cooling effect from the increased surface area, maybe...?
The Range Rover intake tube was also finned like that, but you couldn't see it under the engine cover, so the S-Type & XF kept the smooth tube I guess for aesthetic reasons.
Could be that JLR just ran out of the plain intercoolers, but had plenty of the finned ones left in stock?
daxter1987 (01-09-2014)
There's hardly any oil so it's hard to see it affecting octane in any way that matters. Do you have evidence?
It's also hard to see you being right about the thermal issue as oil is quite good at heat conductance - it's actually used to cool the engine. Again, evidence for it being an effect big enough to matter?
Water is used to cool the engine through the cooling system. Oils thermal transfer properties are poor compared to bare aluminum. It forms a barrier that slows heat transfer. As far as charge contamination anything that acts to affect the ratio of the air fuel mix is going to cause power loss. But with that said you're only going to experience problems with these effects at the higher end of the performance envelope.
